Rust Bucket..?
puckdodger
Oshawa
What's the blue bottle with the braided line all about?
also, I don't know why everything is underlined, sorry?
alaska2baja
alaska2baja
Redondo Beach, CA
2020 Ranger XLT SuperCab, 2008 Yamaha TW200
Adventure Guide
looks like he has fancy shock setup with the reservoir etc.
Correct...I have an APG MidRunner kit on the truck which includes a pair of King 2.5 Extended Travel Coilovers with Remote reservoirs and Compression Adjusters at all four corners.
Stop payment...it's totaled... ?
Kidding aside, when my cars sit for more than a week, the rotors are covered with rust...that the nature of iron brakes...
1pt21gw
West Coast
'20 IS XLT SC / '22 OW BBB 2Dr
Ye' Ole Traveler
Metal + Heating / Cooling + water = Rust .
I have a PNW Mustang from 1970 and rust is what it is all about!
alaska2baja
alaska2baja
Redondo Beach, CA
Adventure Guide
Your rotors look normal. Every vehicle that I maintained in 40+ years of work, looked like this. Not a problem, just looks bad.
Thanks for the re-assurance Chuck
Dsc
Alan
Cambridge ON
2020 Ranger XLT SuperCrew; 2007 Sport Trac XLT; 1969 Mustang Grande; 2014 HD Sportster 1200T
I had this problem of the the rotor face and the aluminum rim corrosion on my Sport Trac. Every time I went to remove the shell had to use a rubber mallet against the tire to loosen it up. Tried a number of anti seize compounds with limited effect. Finally got some caliper grease which I applied to the rotor face and the problem is gone. Just don't over do it and don't get it on the wheel studs. Stuff really stands up to the heat and corrosion.
rydfree
Benny
Maintenance
nothin to worry bout. when the rust is a problem you will know. if you can read reach or pass a beer through it then be concerned. besides more rust is better gas mileage. its not like toyota frame rust, that is the most advanced rust ive ever seen.
Natural weight reduction . I bet it gets better gas mileage now .
WOADKIL
Wil
Cyber Orange County, CA
2021 Ranger XLT Supercrew Cab FX4
RETIRED ENGINEER
Like others have said that's pretty normal. If it bothers you you could always hit it with a small wire brush to knock some of the rust off but I would just put the wheel back on and drive it.
I have to admit when I saw the title I was expecting this to be a Tacoma thread. :shock:
Dust it with WD40. Done! (Not the braking area!)
alaska2baja
alaska2baja
Redondo Beach, CA
Adventure Guide
I was just looking at some Ceramic Caliper Grease options online Alan. Thanks for the tip.
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
Mine were gold plated by ford. Yours has a Factory defect…. Have the dealer buy the truck back. That’s a safety hazard.
