- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,651
- Reaction score
- 8,910
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I played some today, now here is some information regarding fused power that may help.
Note: As I noted any (Not Used) power sources in the BJB (Battery Junction Box) - Engine Bay does not appear to have any contacts installed (so useless) and just blank holes.
However - The BCM (fuse panel) is mostly circuited with power at the fuses and to the connector ports (on the BCM). This is for (per the wiring diagrams) Not Used fuses.
The connectors do not have the wiring or contact pin on the connectors, so you can add a (Tapped) Fuse off of the fuse itself, or for a cleaner wire run (add a contact pin & wire at the specified connector) for that fused power source.
I just updated this today and checked with a meter, I only pulled one connector just as a confirmation the wire is not installed on the connector, however the pin is installed on the BCM port, just waiting for something to be connected. I have been wanting to do this for some time and finally got it done.
Note: for the individual contact pin P/N's they will vary depending on wire gauge, as they are not listed at pin location, so have to use a similar wire gauged P/N and cross it over to that pin location. It can be done but time consuming
And this was my previous guide (for switched power sources only)
BCM - Panel Reference - Note: The longer fuses in the collum are the (3-Legged Fuses) single source power feeding both legs (sides) of the fuse.
