Rubbing issue.
Heezy
2020 ranger
Just got my Ford performance lvl kit put on with 265/70/17 falken wildpeaks and the truck is rubbing when cranked all the way to the right but not left. The picture shows where. Is this normal or a bad installation job?
Rubbing the sway bar? That's a first I've ever heard of this with any setup...
Heezy
2020 ranger
It seemed weird to me to I’m thinking it may be a installation problem but am not knowledgeable enough to know for sure.
Nathan289
Nathan
9 Mile Falls, WS
2020 ranger lariat fx4, 2019 mazda cx3, 1963 falco
Leo
What wheels are you running?
Did you change to wheels with greater negative offset than stock?
Heezy
2020 ranger
Can those sway bars be adjusted?
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
LT "E" rated or regular "SL" rated tires?
I ask because the LT "E" rated tire is 31.9" and the "SL" rated is 31.7". Also, which Wildpeaks? A/T Trail, A/T3W, M/T, H/T, H/T02?
The tire pictured on the Ford Performance Rangers are the BFGoodrich KO2 that are 31.6". Maybe it's enough to make a difference.
Heezy
2020 ranger
They’re the at3w 115t sl rated tires. Maybe a spacer would work?
LoneRNGR
Lubbock, Texas
Systems Engineer
I really don't think they should rub. I wouldn't throw spacers on there without understanding why they are rubbing first. Spacers might just make them rub somewhere else.
Heezy
2020 ranger
Could it be a bad install?
Nathan289
Nathan
9 Mile Falls, WS
Leo
It could be that the caster on the one side is off. Which allows that tire to make contact with the sway bar
