Rough Country 2.5 Leveling Kit Install
ulev1st
Don
West Tn
2019 Ranger CC FX4 ,2012 F250 Lariat FX4, 2017 Shelby GT350, 14 Ford Focus
Retire Marine and Refinery Operator
It FINALLY quit raining here so I knocked out the leveling kit this morning. TOTAL time was right at 3 hours. Understand I had NEVER done one and was OVERLY cautious. The instructions are pretty straight forward. First off raise and level the front of the truck.. don't try to raise just one side at a time cause you will have a stress load on the swaybar.
Pull the tires/wheels, then getting the front skid plates off so you can unplug the 3 electrical connections on the power assist steering. Pretty simple so far.
You have to unbolt the brake sensor and bracket (8mm) and the brake line bracket (10mm).
Next you unbolt the sway bar from the knuckle at the top (18mm). Following that the tie rod end (15mm) and then loosen the top upper control arm (18mm).
You will need to support the bottom of the knuckle so it doesn't lay out too far and pull the axle shaft out of the diff... GUESS WHAT I DID... yeah I'm a dumbass..
Remove the 2 nuts from the bottom of the strut(18mm) and remove the 3 15mm nuts at the top. I had a little difficulty removing the strut til I figured out I needed to lower the jack supporting the bottom some more.
Once you have the strut out you cam assemble the blocks to the top of the strut (mine had too much powder coating on them and I had to round file it out of the holes)
Next step is to remove the bottom bolts on the strut.. They tell you to hit with a hammer.. those bitches are TIGHT. I ended up using a press.
After that you re install the top of the strut (you have to rotate it about 33 degrees for the bolts to line up and re attach with the provided hardware.
Pop the bottom in and then reinstall the studs you pressed out.
Button everything up and double check all nuts and bolts and reinstall tires. I gained slight over the 2.5 I
advertised inches. It sit level now..
For never having done it I'd say the difficulty level is a 5 out of 10. Normal hand tools a jack and some stands.
Taking it for an alignment check tomorrow.
Pics are NOT in order!
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Why was is necessary to remove the lower shock studs?
ulev1st
Don
West Tn
Because with the block on the top it is physically impossible to drop the lower control arm down far enough for the bottom of the strut to go back in it's resting place.
ulev1st
Don
West Tn
Nice write up, my only issue is the use of the Red tools and not Yellow :crackup:
I placed an order for this kit yesterday through @PandaMotorworks. I'm impatiently waiting for delivery :inlove:
Red Rocks.... lol! I actually am replacing my yellow with red as they die.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
since we're voting... Team Red.
Anthony
Anthony
Connecticut
COO
Great write up! So tempted to get this.
I always say any project is much easier to do if you take it one step at a time and not think about everything at once. There's no one step in this project that is hard. So take it one step at a time, don't rush and keep an orderly work area and you are golden!
PandaMotorworks
St. Louis
2019 Ranger 2017 Titan 2008 Ford Focus 2014 Ford Fiesta ST
Tracking is in your email yesterday! along with some goodies!
Thank you for your business
ulev1st
Don
West Tn
ulev1st
Don
West Tn
On a side note tho….. my new Falken WildPeak A/T3 275/65/18s will be here in the morning!
j0shm1lls
Josh
SoCal, USA
www.youtube.com
