Rear Camera error - B115E:08-48
wingers
Northampton UK
2016 Ranger
I've recently bought a 2016 Ranger with a rear camera that isn't working properly. It worked for one journey when I got the car (second hand) but then flickered and stopped working and hasnt' come back since.
I tried connecting via ForScan but the recalibration wouldnt work and failed at 8% as most seem to find.
From what I've read, failed cameras isn't uncommon so I bit the bullet and bought a new one but having fitted that it still doesnt work. Has anyone previously gone around the voltage checks to see what should be detected at the camera connector under different conditions? I'm guessing it is a wiring/connector issue now which is a pain as thats a lot harder to find...
Is there also a layout of the wiring from the camera to the BCM (where is the BCM by the way?)
Regards,
Wingers
Ran
Kev
Klamath Falls, OR
2019 Ford Ranger XLT FX4
I have the same problem. I Can see the same code with my scanner, but could not it to clear the code. I installed a new camera and it did not fix the problem I ahve looked at fuses # 9 and 34, they look good. HELP PLEASE
