Ranger Ford Performance Differential Cover - Now Available
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
Not sure what category this goes under, so exterior it is...
The Ranger Ford Performance Diff Cover is now up at the FP website and available for purchase from @LevittownFordParts.com here. I got my order in yesterday - now the wait begins.
  • Fits 2019-2020 Ranger rear differential
  • Rugged cast iron construction
  • Ford Performance badge
  • Rugged "hammered" finish powdercoat
  • Includes new fasteners and gasket
NVHoonigan
Drew
Northern Nevada
2019 Ranger XLT Sport 4x4
I'm thinking I just found what I will use my FordPass Rewards points on! I bought the maintenance package so I have just needed the right thing to use them for instead of oil changes.
j0shm1lls
j0shm1lls
Josh
SoCal, USA
www.youtube.com
I knew someone would say that.
I almost said in my post and do not say because it says performance.
I left it open and deserved it! :LOL:
Hi Folks,
With all the ribbing and such it seems it would be much stronger than the current OEM diff cover. Probably important to Offroad racers, but for most offroading likely not needed. But if you want your diff cover to look cool..
Not sure what advantage two fill plugs offer. Any ideas?
best,
j0shm1lls
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Hi Folks,
best,
Per the instructions, the top fill plug is not used, only the bottom.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
This alone isn't really worth the extra machining costs, but since it's there, I would use it for a fill vent.
Marshal.
Marshal
Canada
2019 ford ranger, 1979 Mazda rx7
I’m running the ARB one for the Jeep JL rubicon with the M220 diff. Which at least has a drain plug on it. The ford one is the same one available from spicer/Dana, just with a different plaque on it.
Desert_5G
Eric
Arizona
Tacoma
probably thicker and larger capacity for better cooling
Nutty 5.0
SE PA
2020 LB Super Crew, 2012 GT500, 2015 VW GSW TDI
Assuming it has dual fittings ala 13-14 GT500 with track pack as they have the diff cooler. Pump circulates through an external cooler nearby. Definitely overkill but wondering if this is used on the Ranger Raptors or will be on potential NA Ranger Raptor.
porktyme
Roger
Central NC
2019 Ranger XL
Is Spicer 10040651 Differential Cover a suitable replacement for the factory differential cover? It's half the cost of the Ford Performance cover.
HarryD
Western MA
2020 Ranger 4X4 SuperCrew Magnetic Lariat Sport
As this is “Ford Performance”, perhaps the two holes are for rapid pit stop fluid changes. Squirt the fluid into the top hole until it flows out the bottom hole, insert plugs and GO!
