Ranger BOV Adapter! - Boomba Racing
Status
Not open for further replies.
joeb427
It's kind of like an aftermarket exhaust on a 4 cylinder, some people love them and some detest them.
"To each his own"
Though it kind of reminds me of the4 cyl Asian badges with the fart pipe exhaust that makes noise but not nearly as bad..
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
2019 Ranger Lariat as well as many other vehicles.
Making Car Parts!
Dokkenmire
United States
2019 Ranger Xlt Sport Supercrew 2wd
Does your system have it's own valve or how does it interface with stock valve? Thanks!
It just bolts on underneath the stock bov. It comes with 3 longer screws for the added height. Just take off the 3 8mm factory screws and use a phillips head to install the new ones. It takes a few minutes to install and you can't really mess it up. Basically the spacer has cutouts in it so when the bov vents you hear it. There's no moving parts
I don't understand why the GFV's brass piston won't work...o_O I'm guessing the whole stack up will to too tall to clear the hood?
Dokkenmire
United States
If the GFV adds height to the stock bov it probably would be too tall. I was very apprehensive closing the hood the first time after I installed the spacer.
Dokkenmire
United States
Word to the wise, you can't tune with a blow off valve that vents to atmosphere AFAIK. It took me months to figure out why my truck would go into limp mode when I tuned it.
theanswer3
Tampa, FL
2020 Ranger XL
even something like a turbosmart dual port?
Dokkenmire
United States
According to subaru, Mitsubishi, and Focus ST owners the valve needs to recirculate air back into the engine because the computer has already accounted for the return air. The lack of returning air results in a rich condition that can't be fixed with a tune.
I have no idea how much air is enough but the most common advice is to skip vta bovs if you intend to tune.
MagnetiK
I had this problem with my 91 mr2 turbo. From what I remember a bypass valve is different than a blow off valve because one is meant to be atmospheric and the other is returned back and measured by the air flow meter.
Here is a good short article I searched that explains the differences BOV v.s BPV
It also says in the article that a BPV spacer like boomba's would make a BPV 100% atmospheric without issues if not tuned and left stock.
Status
