Project Msfitoy V3.0
kjbeggs
Arlington, TX
Ranger Lariat FX4
Hey Sid,
Can you elaborate on where/how you tied the wiring for the Grill LEDs into the marker light wiring?
Pretty sure I can follow your diagrams for fabricating the brackets and attaching, but I live in fear of anything wiring related...
Hounddog409
Tod
Ohio
F150
Hey Sid, don’t mind telling you that I am blatantly copying your wheel and tire choice. Looks so great! Question: my local tire vendor is trying to dissuade me from going with the Falkens. Too noisy, sez he. What say you?
Have you heard any update regarding the Eibachs?
I had the Falkans on my F-150. My favorite tire to date. By far.
djrobb
Alexandria,Va
2006 Tacoma 4dr Sport Long Bed
Hey Sid,
I just finished the same install. I did the mount a bit differently and will post some pics later and update but here is some of the wiring. The wiring was really easy. The white wire ties to any grounded screw. The red wire taps in to the marker lights. This is done by using an inline tap you can get at any auto supply store. On one side you insert your red wire, and on the other side you straddle it around the marker light wire. Squeeze the tap shut and you have then combined the wires.
The location of the marker light wire is near the base of the battery box. It’s attached to a wiring harness which you can unplug to get a bit more room to work. There is some black electrical tape you can push back some as well. If you use my picture and Sid’s picture you should be able to locate it easily. The wire is the upper left wire on the harness. My eyes said it’s mostly green with an orange stripe (Sid said yellow stripe).
For the white wire I crimped a connector on to it but that’s optional.
To wire the lights together I used butt splice connectors that you crimp then heat to be waterproof.
Hey Sid,
I covered that on the previous page but you can also follow David's install:like:
Snorebaby
Augusta, GA
RJohans
Bend, Oregon, USA
2019 Ford Ranger Lariat 4x4 Supercrew Sport
They're 17 x 9, -20 offset mounted with Falken Wildpeak AT 285/70-17 :like:
I got them through Chris at Pandamotorsport.
THANKS!
RJohans
Bend, Oregon, USA
Oops. Checked on Panda’s site for the Shok’s... They show as offset options either +1 or +20.
-20 is not shown. (Fueloffroad.com adds a -12 to their list of options.)
Can you confirm your offset dimension for me? Thank you, sir.
Sorry, I meant +20...-12 would reeeeeeeelly stick out your tires.
RJohans
Bend, Oregon, USA
Aargh... sorry to bug...
Panda sez they’re selling a lot of Shok’s with a +1 offset. But you got +20 offset. Advice?
Plus 1 is more or less zero offset. Stock wheels are -55 so your wheel/tire would stick out roughly 2 inches. +20 sets the wheel/tire out roughly 1 inch which is what you see from my stance. I personally wouldn't change my choice. Unless you prefer the aggressive wiiiiider stance of + 2 inches, go with +1. I still feel +20 is about perfect offset.
RJohans
Bend, Oregon, USA
Awesome. Thanks. +20’s ordered!
