Plug for Bed lights (dummy) in back on bed rail frame.
Ghost Ride
robert
2020 Super Crew
Some how managed to blow fuse on this plug hooking up bed lights. Can't seem to find correct fuse or location to get it powered back up. Help would be appreciated. Going crazy trying to find right one and location. manual not to clear and the ones i thought it referred to checked where ok. Thanks if anybody can help.
UncleBob
Fullerton, CA
2019 Ford Ranger Lariat SuperCrew 2WD in Magnetic
It might help if you describe which lights/functions don't not work now that you think you have a blown fuse.
Ghost Ride
robert
2020 Super Crew
The lights are not hooked up yet the harness that they are going to get plugged into has no power any more it,s the harness with the dummy plug for Ford bed lights or outlet. had power then lost it after attempting hook up of 12 volt outlet and bed lights. I know it times out after a while its not that it is dead now need to find out what fuse circuit powers that plug.
Figarou
20A Fuse 17 in the engine bay fuse box
Figarou
Changed it still no power something screwed up ?
hmmm.....I know that is the fuse. Not sure what else could have happened.
Ignition needs to be on or else that connection is not getting power .
Ghost Ride
robert
2020 Super Crew
Thanks I 'll check it again. I thought that was
the fuse. have to recheck my work. Nothing ever goes the way it's supposed to.. If can't find out what happen have to run to the battery didn't want to do that. Thanks again.
Figarou
The wiring harness to the lights should have its own fuse. That could have blown.
Did you try plugging something else to see if it has power?
Ghost Ride
robert
2020 Super Crew
Checked the hot wire with tester. Nothing
Yeah everything was working but the pins was making poor connection in the connection so I cut off the plug to make a direct wire to wire splice. When I did I accidentally clipped both wires. then no power figured blown fuse switched one of the other fuses nothing. have to try and find out what happen and make sure key was on and all. Thanks for your input.
UncleBob
Fullerton, CA
mmm? Any chance that is the plug meant for powering the high mount brake light when you install a topper and only has power when the brake is applied? Just guessin'.
