Painting a rusted Metal Railing
Joeiconic
Looking to tap into the knowledge base here for advice on refinishing and painting a metal railing on my deck that has rust on it. See attached pic. I have already done this on my screen porch last year. It that case I hand sanded, degreased, and primed by rolling on Rustoleum Rusty Metal Primer, followed by a coat (or two) of Rustoleum protective enamel. That worked well and it looks great, but this porch has about twice as much railing so I’m looking for shortcuts. Specifically, is there a trustworthy paint and primer in one that can both neutralize the rust AND look good as a final coat? Ideally I would like to light sand it, clean it, and put one coat of paint product on it and be done. Any recommendations?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Swap it out for a wood railing?
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
I have had luck with POR15 but it's not a uv protected top coat and nasty to clean up.
You might try Ospho....https://www.ospho.com/
Sharky
Keith
2020 Ford Ranger 2015 Ford Focus 1934 model 40
remove all the rust, wipe it down with thinner or acetone, let dry.
then paint it or use bed liner on it..
Joeiconic
Joeiconic
thanks all. There are a number of products similar to Ospho and POR15, but a lot of mixed reviews for all of them, which tells me the prep is the most important thing. I guess I’ll end up sanding, priming and painting.
Joeiconic
Joeiconic
I like the bed liner idea. I have a can of the Rustoleum bedliner that I used for another project. I may have to test a sample area and see what it looks like.
Fordup
Ed
NY
youtube.com
For rusty surfaces I have had best luck sandblasting that gets the oxide from the pores. Sanding just goes over pockets unless you go deep.
Dgc333
21 Ranger Lariat
FWIW, the bulkhead to my basement would look like crap every spring. I would spend the better part of a day wire brushing and painting with the damp proof Rustolium every year.
During the late 90's I was restoring my Barracuda and was using POR15 on the floors and trunk. Once cured you could beat on it with a hammer and not damage it. I figured I would give it a try on the bulkhead. I wire brushed it to remove all the loose paint and rust. Used POR metal prep on all the exposed rusted areas then painted it with black POR15. Since it doesn't do well with UV I top coated it with red enamel. That was in 2000 and I have not touched it since.
NOTE: Paint won't stick to cured POR15 even POR15 won't stick to cured POR15. You have a couple of options; 1) use POR primer or, 2) about 3 or 4 hours after applying the POR15 when it is almost dry to the touch you can apply any primer or directly top coat. With my Barracuda I used primer surfacer on the POR15, on my bulkhead I went directly to the top coat. Both have been standing up to the test of time for over 20 years.
Joeiconic
Joeiconic
Agreed, that’s why I’m looking into the so-called “neutralizers” in hopes of cutting corners on the sanding. :like:
Joeiconic
Joeiconic
POR15 seems like the best product, but Im not sure it’s saving me any steps over what I’ve done before. I’ll have to look into it more. Thx
Fordup
Ed
NY
youtube.com
I think POR 15 is the best but go with the instructions fully. Also don't buy too much because once opened it has a short shelf life. Top coat with a good UV protective paint. Wear rubber gloves and safety equipment plus buy plenty of brushes. Not sure if it's shippable to all states anymore with the new VOC codes so check that first.
Jason B
2021 XL STX SE 4x2
machinist
That POR15 looks like good stuff, but expensive and too much work for what you are doing. A good rust remover such as what Phil suggested or something from the hardware store would be suitable.
Then I, personally, would use Coal Tar Epoxy on it, no primer needed. We build sewer treatment plants, and we roll on CTE after blasting.
Joeiconic
Joeiconic
Agreed, it’s like oil and air filters, it’s easy to overthink it!
