Packages and options
FordBlueHeart
Torr
Traverse City, MI
2006 F250 King Ranch 6.0l
Collision Repair Estimator
Thanks everyone for your input. When the 4x4 is engaged will the front axle work the same?
Yes. Still is truly "one wheel" drive, meaning the power goes to the tire with the least traction. Turning in 4wd on dry pavement will cause binding due to the outside wheel turning a larger radius while the inner wheel tries to pivot at a slower speed.
Schafies
Indiana
2017 Ford Explorer. 2019 Ford Ranger.
Thanks FBH. I don't believe the Ranger has an option for an e-lock on the front diff?
Strokerduster
2019 ranger XLT, 2019 Edge ST, 1946 CJ2a street rod, shop full of motoorcycles
Having had drag cars with spools (locked rear), it just wouldn't work. You can push a car with a spool in a straight line but as soon as you try to turn it, you better have some help pushing and you can hear the tires scrubbing as it turns.
FordBlueHeart
Torr
Traverse City, MI
No it doesn't and you don't need it.
Meaning that if you are using your truck in a manner that requires it, you would already know about aftermarket companies that could eventually offer a package for it. Not to mention you would be a serious hard-core offroad player. :muscle:
FordBlueHeart
Torr
Traverse City, MI
My bad. You are correct. I just remember having to get out in horrible conditions to lock the hubs.
I know, it sucks. Ford's ESOF is known to have issues after a few years and then you have to lock in the hubs manually. Many Super Duty owners convert to a manual set up once they need to service the hubs.
kieefer
keith
2019 2WD SuperCab - 97 BMW M3
Locking rear axle question.
Is this a completely different rear end or can a non locking be converted??
Worth the conversion?
Better off ordering one with the LRA?
dmeyer302
Daniel
Carthage, MO
2014 Escape, 2016 Odyssey
Mechanical Engineer
