Sync phones - incoming call alert from the 2nd (not the preferred/primary) phone
Potterz
Pismo
2020 Lariat
Is there any way to have Sync alert you to an incoming call on the phone that is not designated the preferred/primary? (Both phones are set up in Sync.)
SigOris
Greenwood Maine
Retired DoD EE
Highly unlikely as Bluetooth, in most cases, only supports one connection
with syncs use of an 8088 CPU, a very old cpu, I doubt it could do any more than what it can do now
Dgc333
21 Ranger Lariat
Sync only connects to one phone at a time. When it powers up it looks for the phone designated as the primary, if it doesn't find it will look for a secondary phone. Sync does not connect to two phones at the same time.
Potterz
Pismo
2020 Lariat
Experimented and found a workaround of sorts! When your second phone rings, press phones, change phones, and select your 2nd phone. Sync then picks up the ringing 2nd phone's incoming call.
Motorpsychology
Prescott, WI
Vagabond
I believe you can also do this after answering the call from the 2nd phone.
