New (aftermarket) Engine Covers
Muddy Fenders
Judd
Canada
Just my opinion on "fixing the leak"
This does not fix the leak. It band-aids the issue. Much like adding the Ford cover does.
I personally am wrapping my engine in a glad garbage bag to keep the water off of it because I choose to not fix the root cause issue.
Think about using some heavy duty aluminum foil.....
Won't melt, and you'll always have a ready supply of body patch material should you need it. Probably thicker and stronger then the OE body panels.
Stevedbvik1
2022 Ranger Tremor XLT
Make sure to use hat grade aluminum
mokupilot
mokupilot
The Aloha State ?
22 DeeZee Lariat Tremor, 09 Escape Limited
Heavy aluminum tube logistics and transportation ✈
More noise volume means more HP !!! :crackup:
Wait until it works itself loose and rattles like the muffler shroud on an old Toro lawnmower.
Oh Steve....
No....That will not work....Shrink wrap is the answer!
Rhino
jacob
idk help!
professional anime watcher!
Just ask the Honda boys how much power can be gleaned from a $20 eBay exhaust tip...
honda boy here but i paid 700 for exhaust so it wouldnt be loud lmao nothing worse then a d series screaming tbh...
rydfree
Benny
Maintenance
Just got the new engine cover and also ordered some Hot Pepper Red spray paint to paint it with. Need to wait until the weather warms up but I think it's going to look graet.
Make sure, after the install, you dyno the truck to see what HP gains you got. :clap:
Get outta here! Holy crap!
"Transparent aluminum is used for manufacturing bulletproof glasses." as in eyeglasses?
Thanks for the link and this will be on my mind for a long time!
Friday yet?
‘23 Lariat Tremor, Focus ST
Already gained 100 HP just by painting it, I'll report back the final HP results after it's installed. :like:
Looks good! Anxious to see it installed.
