garagetech
- Thread starter
- #1
I just got a instrument cluster from a 2020 XLT Ranger and I swapped it with my 2021 Lariat cluster. Some options do not work with the 2020 cluster that I had in my 2021. The left button does not control the digital speedo numbers. It stays in the split form (speedo numbers are on top small and the miles are on bottom small).
Also the 4 wheel drive does not work on the dash. The adaptive crash option is not working.
I am looking for help with this and does any one know how I can get a spreadsheet with the code descriptions. So this will hopefully help.
UPDATE:
I put all the info from the Lariat to the XLT Module. Left side worked the same and the right side lost the radio volume. I now have errors in Radio, PCM, SCCM etc..
Any ideas on how to correct this problem. I attached photos below
UPDATE:
I did more checking and found out that the cluster is from a STS not a XLT
I am wondering if I the cluster can even be updated or do I need to find a cluster that is from a fully loaded XLT
UPDATE:
UPDATE:
