Multiple Faults
kajnjim
Usa
2019 ford ranger XLT
Nurse
2019 XLT. Driving to work on interstate this afternoon traveling about 75mph. Multiple faults on display to include “service advancetrac”, “hill start assist not available”, “pre-collision assist not available” and obd code “p0616”. Adaptive cruise inoperable. Digitally displayed speed was 42mph while analog displayed 75mph. Seemed like steering was a little less responsive than normal and acceleration seemed a little sluggish. Kinda leaning towards bad abs/wheel speed sensor, but obviously not able to diagnose/confirm anything as I’m at work till 7am and have 6 more 12 hour shifts to go. Did shut down and restart after obtaining and clearing the fault code. Started right up and all messages returned on display. Thoughts? TIA.
kajnjim
Usa
Nurse
Sorry, failed to mention ABS and traction control lights are illuminated on information display also.
SymChris
Mississauga, ON, Canada
2019 Ranger Lariat FX4 / 2017 Escape SE FWD
Hey there, we’re you able to check any further?
As a 2019, unless some wiring has been chewed up, check your battery. With all those things flashing off all at once it could lead to the battery as a good potential candidate of the cause of your alerts..
Langwilliams
Langley
Lorain, Ohio
I was driving a transit connect at work an stuff started shutting off an warning lights started coming on. The alternator was failing. Right before I got it off the highway the power steering went out. It could also be a battery going out. You might try removing the ground from the battery for a while an resetting stuff.
