Multiple dash warnings and abs light on
Indy650
john
Eastern USA
2019 Ford Ranger Lariat
Indy650
Indy650
john
Eastern USA
I have all these warnings coming on for a couple months now. Scanner doesn't show any codes. Nothing works when it comes to cruise control(adaptive or regular) lane keeping other driver assist stuff like driver alert. Not sure what's going on here. Any suggestions appreciated thank you.
RangerBill
PA
Your scanner may not be reading all the modules in the truck. I would use Forscan and a proper adapter to get the codes. You definitely have DTC codes stored with all those alerts.
https://forscan.org/home.html
Indy650
Indy650
john
Eastern USA
Ah I don't know why I didn't think of that I have a forscan setup I just haven't used it in years. That's a good idea thanks!
RangerBill
PA
At least one alert can be fixed by an oil change and resetting the oil life monitor. The others may be a bad wheel speed sensor. Forscan should pinpoint the cause.
Indy650
Indy650
john
Eastern USA
Yeah I'm good with the oil light I don't need an oil change I just gotta reset it.
bbeverag
Normal, IL
2022 Ranger Lariat Tremor
my guess is you have a something grounding out, causing all sensors on that 12v rail to throw an error. I would start with the DPFE sensor since it notorious for failing.
Indy650
Indy650
john
Eastern USA
Thanks for all the replies it's much appreciated. I'll update with results of the forscan findings when I can find the time to do it.
