Mirror Covers
Gibber
Ontario
2021 Lariat Tremor
Does anyone know how to remove the mirror covers on a Lariat Tremor? I saw a video from Australia but apparently the T6 model is different than the North American T6
Danager
Dan
Alberta
2019 Edge
Manager
I did mine a couple weeks ago. Simple. I followed the one that said pry up between the painted cap and the bottom black part, where the mirror assemble folds-in/hinges. Then, from the front side, pull the mirror cap level and straight forward - towards the front of the truck. Start from the outside vertical edge, then work across the top.
It sure sounds like it is breaking. Both sides off, both repeaters swapped, and both sides back on in 10 minutes.
Gibber
Ontario
2021 Lariat Tremor
Yikes !!! Sure sounds like it’s breaking scares me, but I heard about that process as well. Ok, here goes. Thanks !
Extreme01
Glen
Maryland
2020 Ford Ranger XLT FX4, 2008 Shelby GT500
I just wrapped them in Carbon Fiber, looks great..
Kataphrakt
Tim
Grand Rapids Michigan
Ranger XLT FX4 Offroad
Mechanical Engineer - Mirrors
Use a spudger instead of a screw driver and you shouldnt damage the skullcap. The second time i break out the screw driver in the video it was not needed (I thought the bottom clips might have been engaged still), you just have to pull at the correct angle, gently wiggle it a bit.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
yeah its much easier on the truck as the truck is the 3rd hand o hold the mirror.
Like Tim showed start at the lower inboard edge. Mine have been on and off a few times and now I can pull off with just my hands.
Gibber
Ontario
2021 Lariat Tremor
Thanks. That’s perfect. I’ll give it a shot. I hope the Lariat cap is the same in theory. It is different than the XLT.
micl9
Apex, NC
its really basically the same, maybe a bit easier (I have had both)
