Low oil pressure alert?
865RangerVol
Will
2020 Ford Ranger. 2020 Ford Explorer
Our running errands with the wife. Been driving around town (town and interstate driving) for about an hour. Came to a stop and low oil pressure light comes on.
Stopped. Turned the engine off and let it sit for about 5 minutes. Checked the engine and the oil. No signs of oil loss and right at full on the dip stick (technically a little over because it’s hot) but thoughts?
Blue Streak
Larry
Did it go out when you restarted?
geezmo2020
2020 Ranger XLT 2001 Ranger Edge 2017 Chevy Trax 1978 Camaro Z/28 2013 H/D Switchback
Metal fabricator
Possible bad sending unit?
Grady
Christopher
Dallas
19 Ranger FX4, 17 Subaru BRZ Yellow, 11 Evora
Manager
Hot oil will have low pressure at idle. Chances are your low oil pressure switch just may be operating higher than normal. If you are under warranty I would get it to the dealer. If not find a way to plumb in a direct pressure gauge and verify everything.
Grady
Christopher
Dallas
Manager
Yes… I’m worried there’s a short in the pump or something. Oddly strange
The oil pump is mechanical. it will work or it wont since I doubt it is worn.
