Installed the new ARB Ford Performance winch bumper, with pics
RacerBoy302
Fort Lauderdale, FL
XL 4x4 SCAB
I just ordered this bumper; It's now only $495. After a few cold ones had it delivered to my local delaer. I dont have the factory fog light option (XL). Wiring aside, anyone know what size aftermarket lights will mount/fit into the fog light spot on this ARB?
NavRanger21
Indiana
2021 Ford Ranger XL STX-4x4
So, what about their instruction that the airbags need to be recalibrate? Is that just Ford silliness?
So, does this require the airbags to be re-calibrated? If I buy I plan on installing it myself.
LawnMM
Rich
'23 Ranger Tremor
You just have to have a shop that has FDRS software change the bumper setting in the BCM from the factory bumper to the Performance model
It's a 30 second change, unfortunately we can't do it with Forscan, I looked
As for installing yourself, lol it's a bear of a job. I'm doing mine now on vacation and about to roll into my third day ? I'm only pulling about 6 to 7 hours of work per day on it, and I'm losing a ton of time adapting it for my parking sensors and figuring out the adaptive cruise radar
End of day two I've got it hung on the truck, have to torque everything tomorrow and install some little trim plates and finish installing the ACC
You'll need a 21mm socket and a 17mm wrench to get it done, those were two items I didn't have on the shelf
Living The Dream
Where did you find it for $495?
Got a link?
Thanks!
R80GSEric
Eric
Monterey
19 Ranger 4WD Lariat, R80G/S, 05 Ural Gear Up, 70 SL350
Hi Lawn and Mapco, looking great! Can you help with some questions?
- what size drill bit did you use for sensor holes
- can you mount winch with bumper installed or must winch go in first
- what ACC mount did you use
- how many inches of leveling did you need after bumper and winch
Thanks in advance! Mine’s ordered and I’m prepping parts and tool lists.
LawnMM
Rich
'23 Ranger Tremor
1 3/16 will get you the right size, you then need to mark and cut the little keyways with a Dremel side cutting bit
The two piece sensor sleeves are keyed so it doesn't rotate. The piece that slips in from the front has the key nubs that you have to cut little notches for.
The rear sleeve has little plastic feet that stand off the back of the bumper, the new bumper is fatter, you have to sand those down a little so they clip on properly from the back, two seconds with a sanding wheel.
I used a cali raised ACC relocation bracket, and cut off most of it. I'd have to take some photos to show you how I made it work but it works perfectly. And you can adjust the elevation and windage of the ACC radar.
As for leveling, no idea I haven't leveled my truck, mine is a Tremor model and I see no difference from the stock bumper by my eye. I do believe you can mount a winch with the bumper already mounted, there's an assload of room when it's installed.
You probably would need a jack or something to lift and hold the winch for you, though, they weigh almost 90lbs by themselves. I've not mounted a winch yet.
millva
Ray
VA
Ranger Lariat 2022
Which Ford part numbers did you use for the sensor sleeves?
Thanks!
