Installed ARB Compressor
Alex Bedrosian
Alex
Salt lake city
Ranger xlt fx4
It is not pretty, but it works, and I only used what came in the box.
I used to have a tendencie to over engineer things. I have since made a mission to aim at "simplest design," when working on projects now.
I saw other ways this compressor was installed, I likes all the ideas and my wheels stared to kick into over drive, UNTIL I opened my hood, removed the plastic cover and saw a hole and a strange indent. I though, "huh, looks like that mounting plate they sent me would fit in there." It did.
I bent the plate
Moved the ARB compressor blue sleeve all the way to one side (side shown in photos)
Mounted plate to compressor
Lined up right hole on plate with existing hole under hood (loosely dropped bolt in) drilled a hole for left hole in plate (slight smaller that provided bolt) and used my drill and to have the bolt thread itself into hole and hold.
Pro's- cost nothing, simple design, works, can be very easily removed,
Cons- plastic cover can no longer be fully put back on, hood needs a little little little extra umpf to engage lock (due to plastic cover), could potentially have problems if going over lots of bumps at high speeds for a long time (but we will see)
P.S. I also tore apart that rat's nest of a wiring harness and cut it wayyyy short to suit my needs and existing switch set up.
burchs
Stephen
Louisville, KY
2020 Ranger XLT 4x4
Just looking at setups for a compressor and so far I like this spot! Is there something preventing just trimming that plastic piece to fit around the compressor so that the hood closes normally again?
Thanks
KnightRanger
USA
2020 Ford Ranger, 2016 Harley FLSS,
bka0721
Bryan
Boulder, CO
2025 Ranger Raptor - 2020 Ranger XLT 4X4 SupCrew - 2008 F550 4X4 Crew Cab Dually
Retired National Park Ranger (Grand Teton/Yellowstone/Rocky Mountain National Parks) - Retired State Trooper
Looks like you did a really great job of a clean and tight installation.
Do you have the Model/Part Number on the ARB Compressor you used? Do you have a list of anything else you recommend was/is need for this install?
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
I wonder if anyone has considered taking the OBA Pump an running it to a slender 5 gallon tank under the truck. Then when you are getting close to coming back off the trail, you flip it on, pump fills tank and when you are at the end of the trail, you can quickly fill all four tires because you have a reserve of pressure.
Alex Bedrosian
Alex Bedrosian
Alex
Salt lake city
Ranger xlt fx4
Thanks
Hey,
I have actually not considered that as an option LOL
Alex Bedrosian
Alex Bedrosian
Alex
Salt lake city
Ranger xlt fx4
it is the Arb Compressor Part Number: ARBCKMA12 , and when I started I decided to only use parts provided, other than a hammer and a vice (even a concrete step or curb would work) and a drill/bit nothing else is needed.
Alex Bedrosian
Alex Bedrosian
Alex
Salt lake city
Ranger xlt fx4
I have a friend who did this, My next plan (when I have $$ i dont care about) is to move the compressor into my bed and run house to the 5Ga and then a line to the front bumper and out the rear. I have a long list of their things that are taking funds at the moment. there is ALOT of space under this truck for a tank IMO.
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
http://openroadtuning.com/steel-5-gallon-skinny-tank/
I don't care for four ports, but the shape makes it a winner.
jblc
JB
USA
2021 XLT FX2 supercab
This was a great idea. I did the same, with some modification. See last photo for quick-disconnect connector. From the top, the connector pokes out very little (~3 mm) beyond the tailgate, so using the bumber step is still easy.
jblc
JB
USA
Some more photos from under the body, of the tubing leading to the back bumper's connection point. It's routed in a way that minimizes debris that could hit the hose.
Note that I have a quick-disconnect in the engine bay as well (directly from the compressor), in case the hose to the rear connection point ruptures for any reason.
If the hose is damaged, I can disconnect that line, and connect the hose used for airing the tires, directly to the compressor (which is the usual approach anyway).
Mentioning this idea in case anyone else routes a pneumatic line, and is looking for a method that includes some emergency backup.
Behind the bumper, connecting to the industrial connector shown in the previous post. The connector is rotated so that the tire-removal iron still has clearance.
Not to sure how I feel about that much hose running that far for just one little compressor in that diamiter but to each thier own. If anything you do have the advantage of having some volume for storage.
Here is my little setup just in case you didnt see it on the other thread
jblc
JB
USA
I liked your setup as well :) I just don't available space in the bed, hence placing it elsewhere.
50' (25 ft under car + 25' filler hose) of 1/4" hose should be fine, since the compressor output is 90 psi, and tires are 35 psi max.
