I have joined the 100k miles club
OrangeStreak
New Mexico
Definitely drive the hell out of my ranger. Unfortunately not trouble free I’ll list below:
upgrades:
- aftermarket engine cover
- NGK spark plugs
- Turbosmart BOV
- Oil catch can
- bully dog 91 tune
cosmetic upgrades:
- “FORD” grill from Ford themselves. Says ranger on top too
- Rear diff cover
- side step rails
- Light bar
- LED lights on top
- weather tech bug deflector
- weather tech rain guards on windows
- one size bigger tires
- weather tech floor mats
issues:
- water in spark plugs. Hence why I bought the cover and such
- transmission issues (fixed with help of Ford and a good tranny flush)
- back passenger axle basically disintegrated, completely replaced
- lots of rear wheel speed sensors due to axle
- infotainment center is constantly needing to be restarted due to freezes.
- gas tank float failed (don’t need it fixed until inspection/smog after year 8)
all problems aside, I’ve got my danger ranger basically perfect at this point. I expect my turbo and tranny to eventually fail but hey if I can get up to 100k I can’t be mad. In fact, I’m going to go drive it another 120 miles for work right now haha
What were your particular transmission issues (symptoms) and fixes for them? Thanks.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
MXGOLF
Sales / Photographer
Congratulations Jacob. WOW it's going to be a long time until I hit 100,000 miles. I am at 14,000 with just over 3 years of ownership. I do have three vehicles too. The weather has been so nice since I bought Lucille I ride my motorcycle a lot to work.
pbethel
Patrick
kingman az
The rear axle shaft started to break apart. They think it started with the rear wheel speed sensor and the baring it uses to read the speed. If your truck is eating the speed sensors, have ford look at the axle. Might save the $1000 repair bill
This is why an actual location, at least to area of the country is important. NE, SE, SW, PNW.....
I am not going to be concerned about my tone ring because the most common cause of breakage is rust jacking. Mostly in areas that use a lot of salt in the winter. If Jacob is in Tucson maybe I and others in the desert might need to worry a little.
Jacob
Jacob
Jacob
USA
2019 Ranger XLT Sport 4x4
Foothills of California so no salt….
Jacob
Jacob
Jacob
USA
Shuddering, hard shifts between 3 and 4 with over revving at times.
So far the only fix that has held longer than 5k miles has been the full tranny flush. I’ve tended to never do a flush as I was worried the smaller particles would get stuck in other areas of the tranny. Seeing the difference after having got it done, I had misguided fear
Jacob
Jacob
Jacob
USA
What engine cover did you buy if not OEM?
I bought the aftermarket metal one people have posted on here. It is doing the job of protecting from water for sure…. Unfortunately it also already snapped near the front bolt…..
Racket
Here and There
Transient
  • Wow
Reactions: KNI
You don’t spend your weekends at the ISS as well? I thought everyone did
Planning on painting my room green and loose some weight...
pbethel
Patrick
kingman az
Yep, that detail will lead the bad guys to you.
So I guess I might should take note and worry a tiny bit. (meaning I WILL file that away in case I lose a rear wheel speed sensor.)
Rebel Ranger
Stephen
Tampa FL
Insurance Case Implementation Specialist
Just broke the 100k mile club today. Just shy of four years. I’m having an extra beer tonight to celebrate
Congratulations! At the rate I am going, it will take me another 8-10 years to get there!
