HOW TO CHOOSE THE RIGHT BULBS FOR YOUR VEHICLE
AUXITO
Diamond Sponsor
AUXITO
AUXITO Senior Manager
INTRODUCTION
Most car owners don’t think about headlight bulbs until one dims or stops working. Then comes the challenge of replacing or upgrading them, which requires selecting the right size and type. Luckily, this guide will help you navigate these decisions with ease, ensuring you choose the right bulb for your vehicle.
HOW TO FIND THE RIGHT BULB SIZE?
Not all bulbs are universally compatible. To ensure the right fit, follow these methods:
A. Use the AUXITO Bulb Finder:
  • Visit the AUXITO online bulb finder page or their official website.
  • Select the category (e.g., LED Bulbs).
  • Choose your car's year, make, and model (e.g., 2011 Dodge Challenger).
  • Specify the bulb location (e.g., high beam, low beam).
  • Select the type of bulb you want to replace (e.g., halogen, HID).
  • Review the results for compatible upgrade bulb options.
  • Note: If your vehicle is not in the database, consider using alternative methods.
B. Check The Owner's Manual:
  • Refer to your vehicle's owner's manual.
  • Look for information on bulb sizes and specifications.
  • The manual should provide details for each type of light in your vehicle.
  • If information is not found, contact the manufacturer for bulb fitting details.
C. Inspect The Current Bulbs:
Remove the bulb and check the base for size information (e.g., H7, 9005).
* In the meantime, I've consolidated a full set of bulb models on the Ranger, so if interested, check out my previously posted POST!
Trustable
4Runner
Not that your average customer will pay attention or have the knowledge to understand why, but its nice to see a company have the fortitude to mark low beam LEDs in halogen housings in the "off road use" category.
Nothing better than getting blinded by a lifted 02 Silverado and very cheap led bulbs in halogen fixtures. At least that seems to be the preferred activity around my area.
AUXITO
AUXITO
Diamond Sponsor
AUXITO
Thank you for your kind words. We sell extremely high lumen LED headlight bulbs and recommend them for off-road lighting. Since everyday driving on well-lit roads does not require high lumen products, we recommend upgrading with lower lumen LED bulbs, whether it's to add illumination or change the look of your vehicle, led lights are a great choice.
And a good cutoff is key for auxito to make led bulbs, we want to be able to shine the light at the same cutoff as a halogen light no matter how bright the low beam is.
Colo_Ranger
Do you offer a front turn signal that is ONLY white? I'm incredibly vain and the orange bulbs clash with my yellow fogs and running lights.
AUXITO
AUXITO
Diamond Sponsor
AUXITO
Hey dude,
We have the product you want. But honestly, I would recommend amber turn signals for added visibility or to avoid violating road laws (I'm not sure how it is in your state)
If you just want white, you can click on this link:
https://www.auxito.com/products/upgraded-7443-led-bulb-3200lm
And I'd recommend this white and yellow toggle turn signal for you.
It's white when you turn on your parking lights and amber when you switch to turn signals:
https://www.auxito.com/products/led-front-turn-signal-light-bulb-for-2019-2021-ford-ranger
The bulb size this message replies to is 7443. Based on the results of the 2021 Ford Ranger XLT FX4 query in your profile.
If you are inquiring about a different vehicle, please let me know as the bulb SIZE used may be different for different year models.
Colo_Ranger
Hey dude,
I checked on the laws here and there is no color rule. I will debate, although no one here pays attention to turn signals and 90% don't use them anyway...
AUXITO
AUXITO
Diamond Sponsor
AUXITO
Are these actually blinker bulbs or just white?
I understand your concern: are you worried that this product is always on, like when you turn on your reverse lights?
The truth is that LED bulbs are simply a replacement for halogen light bulbs and have no other function. The bulb is controlled by the bus system in your vehicle, and it performs the function of this application in whatever position you install it. So it is with LED bulbs.
We make multiple colors for the same model just to meet traffic laws. For example, the product I'm recommending to you also has yellow and red options that can also be used as front turn signals on your vehicle because they are the correct model number.
I hope this explanation helps you understand.
My link is just a suggestion, likewise, you can also look for other brands of white 7443 bulbs that can all be used for the front turn signals on your vehicle and also attached to your purchase needs.
Colo_Ranger
Mostly, wondering if the running lights are dimmer and get brighter for the turn. It helps. I just want my colors to match because I have a problem and the different hues make me mad. ha!
AUXITO
AUXITO
Diamond Sponsor
AUXITO
The original halogen bulb for the 21 Ranger front turn signals is the 7443 model, which has two wicks, the thicker wick works when performing the turn signal function, and the thinner wick works when performing the parking light. You'll also notice that it has two pins.
And the 7443 LED bulbs for sale also have two pins for different jobs, so it's the same as the original halogen lamps, except that the illumination shoots light from the led wick. I attached a picture:
Again, I randomly checked other brands of 7443 bulbs, and they are the same.
So what bulbs don't apply to your vehicle? I think you might want to keep an eye out for ones that have only one pin but are labeled as a 7443 model number, they only perform one function, which could be turn signals or parking lights.
