How I Modded a 22 Ranger Tremor With The Warranty in Mind!! -Ford Performance Tune (FPT) and JB4.
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
After 22 years daily driving a 99 XLT 3.0l 4x4 manual, I just had to get a new truck. When is better time than winter and a crashing used car market? Different story, different day. Point is I got it with 5000 miles stock.
Disclaimer: This is NOT a get out of Jail Card with a dealership or Ford. The idea is designed around Factory limits. If it fails to pass warranty it fails, and that is on the owner. This is a guide on how it could work if you wanted to try. If it does work out badly I will update the Thread. Cheers!!
Setup
JB4 package
Ford Procal 4 with tune. Best Prices is ever seen
AFE Rapid induction Intake. Open or closed design. HERE
AFE cover Here
AFE Scoop (Red). Looks cools and it is Tremor red like the trim color
Velossa Big Mouth Ram Here Why not. It did do a little better Mpg unit I didn't care any more.
MBRP 3" Stainless Catback exhaust Here
Go-fast recurring value
***** Updates*******
- Added CV Fabrications Intercooler and Coldside Pipe. Did really think much about performance since they really don't usually add much but I was dead wrong. More Torque!! quicker!! I got to say the Throttle response is 20% better.
0-60 (Before intercooler and Cold pipe. 6.29Sec Best. (Average 6.5)
0-60 (after intercooler and coldside pipe) 5.78Sec ( 2 passes only)
other mods should get some credit too with such a change in performance.
Going Beyond Rational
I always wanted to mod my 99 truck but it was just too reliable and not worth the money for power. So when I picked up the 2022 Ford Tremor I was Itching to do something. I never thought it would get this bad. Note that what I explain next is not a guarantee, but based on community knowledge. It could protect most of your warranty.
Buying the Jb4 was my first choice as it was the only one that doesn't expose the Vin to Ford as altered. Yes it has been hashed that the Ford Tune will be protected by Ford Performance. No, I don't trust anyone so JB4 it is. Yes, maybe.... if they check this.....do that.... it wouldn't work. Idea stands it is not detectable.
The Jb4 is a great option for getting the most out of the turbo. It adds big power compared to the Ford Tune and it is not close. I have not verified FPT over JB4 separately myself, but we have some numbers. I have my numbers here, and butt dynos matter. I'll get to it. The suite of options will keep you busy for some time IF you are that gut. Otherwise plug it in and go with minimal setup. Shout out to @Terry and the team at BMS. They probably hate me now. I am "THAT GUY" about needing to know everything I can. Now I'm giving it to you straight up. I'm still learning more so I'll likely continue updates.
This is no shill for cash!! I wanted to do this and get it out there for everyone interested. Also, I cut through the muck and haters, and got to the truth with Receipts.
Before we get in to the tune. If you go the JB4 route, do yourself a favor and buy the complete package with app. It is not a budget alternative and you'll miss out on most of the good stuff. There is much more than boost. It is whole platform.
Here is a Free Link!! If I had a Affiliate link I would have use it to pay for my sins and mistakes.
https://burgertuning.com/products/jb4-for-ford-ranger-ecoboost-and-raptor
Get:
JB4 module
BT connector
Jb4 App
- you need these
First off the JB4 at 93 Octane is good. see map 2 Results. (BMS data below) Not Mine
The JB4 alone will smack the boost gauge in the face. Gear for Gear it is more fun but you have to be good with the response curve. Sport mode is recommend to get the best results. If you want that pass his ass on the highway ability. You can go JB4 solo. I wanted the transmission tuned and that's how I ended up in this.
The key here is adding Ethanol to the mix and proper JB4 setup. The 2.3l Ecoboost Ti-VCT system senses fuel quality automatically. It will advance timing in the presence of Ethanol or high octane fuel with out a custom tune. For that reason I can't support running Rot gut 87 octane for these motors. They need to run premium. For the power, the milage, Efficiency, and longevity. E30 blend fuel profile take advantage of the near Race fuel quality cheaply. Couple gallons of Flex fuel and some good 93 gas, you got a race motor. Just flush a tank of 93 ever so often to burn out residuals and keep it clean.
On E30 I can get JB4 running map 5 without major concerns. However, It was best in Map 3 or Map 4. Truth is the JB4 will push the turbo out to the Max all by itself. Map 5 targets 7 PSI over stock. The safety's feature help prevent issues and all the Factory Safety limits are in place> There are a lot of them BTW. BMS - Map4, Map 5 dyno number are above. ( E30). As you can tell the raw numbers are significant. It is noticed in the seat for sure. The torque is disgusting for a 4 banger pick up.
Ford Tune Dyno below. not my truck.
A Ford tune is a complete Calibration package. While The Procal 4 is all of 2010 tech style, It is has every tool to monitor what you want. It has useful options you just can't get elsewhere. This Package gives you that nice response and crisp shifts from the Transmission. You can recalibrate Fuel trims and Relearn the Transmission module. Cool stuff people don't mention often. It is almost worth the money with out the tune voucher.
Note: to keep the Warranty on a FPT, be prepared to pay up to $500 To the dealer for installation.
Ok,OK, The Rub
I needed to know what a transmission calibration would do. It was eating at me like a rabid hound. My choice was custom or Ford Tune jb4 stack. I knew the Ford tune had obvious draw backs but it does maintain safety limits. The warranty and the peace of mind had me wondering how a stack would function. So here we go.
Stacking a JB4 on the Ford tune is NOT going get you 30 PSI ripping down the highway. Not because it can't ask for the power, rather it will likely destroy your engine or Max out the failsafe's. I have been past 25 Lbs for just a movement. unnerving. My failsafe in Jb4 is 25 PSI. Stock turbo is at the limit up there with diminishing returns. It is not efficent and dangerous. The ECU cuts throttle and pushes fuel in past 4500 rpm. It will run very rich down to about 10.5 AFR to protect the Cat. That is the tune limit. Other tunes can account for this in other ways and get you more top end for the warranty trade. What you get between the margins is fantastic!!
The Up Shot
Now this is fun part. The combination of the Jb4 and Ford Performance tune makes for a Rowdy, ROWDY!! Ranger!! at about 23-24 PSI max in Map 2, The Dyno Came back impressive for a setup that can pass emissions and SHOULD be warranty valid in 30 minutes or less.
-Stacked Dyno Jb4 & Ford Performance tune. FPT (RED) Map 2 (Blue) Map 3 (green). on E30 Fuel, 5th Gear pulls.
At first glance it appears the stack is not much more powerful than the JB4 alone on Map 5. There are a lot questions marks about the comparability of these numbers. I had to do 5th gear pulls which is not 1 to 1 gearing. That would need 170-180mph in 7th. However, the meat is in the Low end and middle RPM Range. The consistent power delivery is seductive. I am confident something else can be down without major mods to improve the top end. Keep in mind there is power loss doe to gearing, my dyno numbers are likely average low.
The Butt Dyno speaks. with a simple Ford tune, a reset of the KAM learning on the Procal, a Jb4, and some shifty driving, this truck Eats!!. I will try and get the 0-60 numbers but I have Drag strip numbers for you all.
Note: I had never ran a Quarter mile before so my experience is zero and this is raw. I was spinning tires and make all kinds of mistakes.
Best effort at Capital Raceway Maryland - FPT+ JB4 Map2
14.324 - 1/4 mile
2.204 - 60 foot
6.077 - 330 foot
9.265 - 1/8 mile
11.994 - 1000 foot
96.85 MPH
The truck is topped out at the end of the race do the fuel dump, boost drop, heat, gearing or all of it. I still have a stock intercooler. Inside a 1000 foot, and down in the 330 foot area, nobody was touching the truck. Chargers, Naw, Coyote f-150, naw. Bimmer, Hell naw!!. I still have a lot of work to see if I am missing something but the reality is this truck moves point to point like bat out of hell.
it keeps sustained Torque curve between 350-384 from 3200RPM out to 4400RPM.
HP peaks at 4400RM. unlike the FPT tune sheet at 5600rpm max 284HP. It so strange in that way. The power just drops off at 4500rpm on paper. On the street you don't feel that much. But it is a whole ton of fun getting up the road. Still has all the Ford safety protocols and 10 gears use. I can pull the Jb4 tomorrow and nobody is going to tell short of a autopsy. (Maybe)
With out the JB4 I can't take advantage of E30 unless a custom tunes made. At 93 I can just run base FPT all day No problems or map 1 with JB4. I don't need to Flash a ECU every time I change Fuel or my mind. If I want the go fast feeling I hit the KILL button.
ALL this doesn't take into account that i am working out a User Map on the Jb4 known as Map 6. Defined by me, based on my needs. i could possibly work out deficiencies. The JB4 accounts for my E30 blend with a Fuel It Ethanol Sensor kit. I know also that it is not required to get similar results on E30.
If you already have a Ford Tune but want more and keep the Factory safety limits, this might be right for you.
The Monitoring and logging of the JB4 with all the options is amazingly convenient. There is built in Pedal mod that pulls the slack out of the pedal for better response in any mode. You can change maps per driving modes. example, say Map2 is D, Map 3 is Sport, or Map1 is tow mode. Perfect.
Bottom line is the stack is more fun, less worry, and runs faultlessly. I made 8 passes at the track in various configurations, never needed to step out of the truck. Logged and tuned on the fly. Between the JB4 and Ford Procal, I got all the info I needed. Air temps, Trans temps. boost, ecus known boost, DME requested Boost, AFR, Trims, just everything. Total control. Tomorrow I could pull the stuff off and pass emissions or do service work.
I may get itchy for something different in the future but I am on to more hardware. Intercooler, then possibly on to catted Downpipe. At that point I may move away from the combo. but I always want the Data logging and other JB4 features. I didn't even mention most of them. Yet. You want to run Method injection? Jb4 can control that for you. What else do you need?
Hope this is useful. Let the FUD begin.
Rp930
Denver
When something goes wrong and the engine expires it will likey set a fault. The fault will log all current parameters. How do you intend to explain the excessive boost among other parameters to the Ford warranty department?
Jason B
2021 XL STX SE 4x2
machinist
Impressive numbers, but will JB4 back you up in case of failures and guarantee Ford can't 'see' the tune?
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
It could happen, The logged boost on the ecu is viewed as, "with in operating range", via the way a JB4 interacts with it. The ECU will log corrected boost but it is actually pushing more than stock. The whole point of the JB4 is to push the motor without tripping failsafe's. This FYI for the froggy.
I'll say this. If you want the power and are really concerned with over boost, run the Maps conservative until you are out of the warranty windows. Jb4 can add boost in normal Range but more aggressive at certain times. I have never had the ECU throw a code for boost the whole time I used it. Best Wishes.
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
Yeah, absolutely not! HEHE. buyer beware. BMS makes no such claim either. I have to assume it is working bc is has not thrown and boost codes or any code related to that.
pbethel
Patrick
kingman az
Sounds like someone with a vested interest in the product.
Rp930
Denver
I'll say this. If you want the power and are really concerned with over boost, run the Maps conservative until you are out of the warranty windows. Jb4 can add boost in normal Range but more aggressive at certain times. I have never had the ECU though a code for boost the whole time I used it. Best Wishes.
Good luck. I would like to see a freeze frame for a fault with higher than normal boost pressures. The snapshot on vehicles during a fault is very extensive. I would also be concerned about what a Ford service engineer can see with his equipment after a fault or failure. My experience with another manufacturer tells me we could see much more data than you can. But, hey, carry on by all means. Not here to stop you just want to learn more about these types of controllers. I would just be careful stating your warranty is not affected, it likely could be. The engineers are no dummies.
I would also add it is not beyond the dealer or manufacturer to search your email online for mods or track info. We were a smaller company but when money is involved it can happen. It becomes a challenge.
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
Yeah, I bought it and use it every day. I want it to work well. The numbers are for you to decide. I already did it. best wishes.
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
I can adjust the wording if people think it is aggressive. I tried to point out the "(maybe)" part in the title. I'll refine it. Thanks.
Part of what I learned is many times services departments are not diving into these issues the way a CSI agent does a crime seen. So if you murder your engine it is good odds nobody is going to go that deep to find a serial killer. Like anything, it is risk scale. cheers.
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
Here is a interesting point. I have run 25 PSI. No codes, no limp mode. It has never backed off due to this. After reading these devices running on bimmers for 9-10 years without issues It adds more confidence. If the Germans can't find it who will? Ford!!
Rp930
Denver
If you scatter a Ranger motor I am quite sure it will be scrutinized. They don’t just blow up. The dealer will do what they’re asked so they get paid. But go right ahead.
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
Update. The product is designed to function with in factory limits when it comes to critical safety metrics, Temperature and timing Ext. The added boost it self is not a concern unless it trips something else. We are filling in headroom here. Better Fuel, more Boost, more timing, more Woot Woot!!
Dereku
Chicagoland Area
I would be careful with JB4. They intercept and change specific signals. I would not help anyone install this on their vehicle unless I really didn't like them. 60k goes pretty quick. I just waied for that. By changing signals you are over fueling and running excessive EGTs which typically are not an issue in gas engines. Our little turbines are well out of their efficiency range at 25psi. Even the focus RS folks who have the hottest factory 2.3 limit to the 25-27 range.
Talk to an established tuner not one of their sales reps and they can go into great detail. I have tuned everything I have owned for the last 25 years. Even tuned a few myself. The amount of effort that goes into timing, fuel tables per gear, boost per gear, and shift pressure is pretty intense.
Be careful with your truck, but it is your truck not mine. Knowledge is power, arm your self with all you can.
DROZ23
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
Thank you.
See this where I notice a disconnect on what it does. None of the safety tables change. The boost is altered yes. The safety signals are upheld. Go outside spec and it trips on the jb4 anf Back to stock you go.
I read a hundred logs and blogs. I rarely com across all the warnings actually playing out. Almost none.
Here is a bronco 20k miles on a jb4
https://www.bronco6g.com/forum/threads/jb4-tuner-review-install-10-000mile-update.37644/
Sure, be cautious but you can't turn on 100 psi and throttle to explosion. The ECU will not allow that.. it pulls back. Boost targets are missed all the time do to safety measureS. Many of them.
Thanks for your feed back. I do appreciate it.
