hitch questions / recovery w.l.l. possible hot girls...
Theoretically, if you were able to install a proper rated recovery point on each frame rail, you could use a short static strap (tree strap) to construct a bridle, then pull on that. Or you could just pull on one of those rated recovery points.
yes i always prefer a bridle to divide up some stress. i carry two tree straps just for that.
Glocker
Boca Raton
Maybe try finding some of the Tremor rear hooks for sale used?
khyros
You could also just mount your winch on the front, and then do a reverse winch if that's the needed direction, securing your rear point as a proper hitch shackle. You just need 3 snatch blocks, enough tree protectors for them, and probably a winch extension line. More details below.
pbethel
Patrick
kingman az
The re-direct snatch block with no scale hooked to it might have had the highest load of all.
Pulling on the center of a long line imparts a very large force. Rigging class was many years ago but we were taught to be very wary of shallow angles like that.
nice video!
