Headlights stopped working
OC4095
2019 Ford Ranger XL
Factory Automation Engineer, Auto School Grad, Car Audio Tech
Anybody seen this issue? Fogs work, high beams work, but no low beam (or DTL). Bulbs are good and no voltage at light.
OC4095
OC4095
2019 Ford Ranger XL
This was interesting. There is a hidden fuse box on the bottom side. Took me 10 minutes to find it. Fuses checked out.
Apples
Alan
Roswell, NM
2019 Ranger XLT
There is a relay which controls the DRLs. And, there is a resistor too. If the relay is bad, or the resistor is open (the usual case), there DRLs won't work, and there will be no voltage at the plug.
If memory serves, there are tow procedures to follow; one for LED and one for halogen lamps.
OC4095
OC4095
2019 Ford Ranger XL
Do you know the location of the relay and resistor? These are the halogen lamps btw.
Langwilliams
Langley
Lorain, Ohio
I assume there's a control module that turns the lights on when they're supposed to come on. Wonder if it's locked up. I would try disconnecting the battery for a while an see if it clears.
OC4095
OC4095
2019 Ford Ranger XL
Thanks, I tried that and it didn’t resolve it. ?
OC4095
OC4095
2019 Ford Ranger XL
We’ll I’m an idiot. Now that I’m fully awake I realized I pulled the wrong bulb earlier. They did in fact both burn out at the same time. H11s hopefully it’s just that, I do have 12V at the connector.
Thanks for the help.
Apples
Alan
Roswell, NM
2019 Ranger XLT
No, without doing a lot of research. I have the extended service manual for my 2019 XRT, which I paid for. The file is 350 megabytes. I can send it on my direct to net fiber link, but most ISP do not allow such large files to be received.
I suspect (I haven't tried) you can find the issue on the net with a bit of searching. Obviously, your dealer should know about this issue (it is a common failure mode), and should either be able to fix it, or if you're lucky, tell you where to look.
