Gun Related Pictures and Chat
Glocker
Boca Raton
Been wanting Glock 19X forever, but I never got it because I had no practical reason to... With Glock discontinuing (almost) all models & changing design on them, I finally pulled the trigger on one:
Very nice choice.
But have you actually pulled the trigger on it yet?
Glocker
Boca Raton
I posted up above about my latest project - Project Mossturd. I am blinging out a junk Mossberg in nickel plate and gold.
It was time to remove the finish and polish the receiver. This was harder than I thought...
I managed to sand off the black anodized finish from the shotgun's receiver - it was a little harder (the finish hardness) than I thought it would be, and required a more aggressive grit of sandpaper. From there, I used progressively finer sandpaper, and also WD-40 for wet sanding. I then used Meguiar's Ultimate Compound and Ultimate Polish, before finishing with Flitz.
What I failed to account for in this whole process, is how soft unfinished aluminum is! If you even think about glancing at the receiver, it gets little micro-scratches! 🤣
Next step is to now put away all the polishing stuff in my garage, clean up my little ad hoc work space, and set up for plating!
Sharky
Keith
PA
2020 Ford Ranger 2015 Ford Focus 1934 model 40
Lexington ammo plant to close temporarily ......https://www.msn.com/en-us/news/us/a-us-ammo-plant-is-closing-and-shooters-will-feel-it/ar-AA1SJLra?ocid=msedgdhp&pc=EDGEXST&cvid=69473bbea61d431fb78a396887af451b&ei=12
woodworker
Joel
virginia
2021 Ranger Sport
Awesome...let the fun begin:like:
Reposting some prior images in various threads...now at home here:)
Starting with my trusty Colt 1911 government model modified over time with a lot of home smithing, custom trigger/springs/beaver tail, Four Star target barrel 4 port comp, recoil damper springs, Recover frame grip with optic rails, Talon grip tape overlay, and Truglo green laser/flash light, 10 rnd extended mag. Trigicon adjustable target sights :)
Love some 1911’s
DocE3Gun
Dillen
Missouri
2020 Ranger Lariat Fx4
self employed
I would imagine that was an out of battery detonation, which shouldn’t make a difference between factory or handloads……unless the handloads used benchrest primers.
javelina
Gregg
AZ
2025 Ranger XLT 4x4 (yep, 6G), 2024 Braptor, 2018 F-150 RCSB (4x4), 2006 Jeep TJ
IT
I need to drop a new trigger in my 9" 9mm custom SBR. The ECHO trigger broke and wounded a buddy sitting beside me at the range. I had to pick a piece of brass out of his flank at the range.
Wholly sheep sh**! Good to hear all are ok!
Deleted User 38384
Was it a hand load or factory ammo? No other damage to the gun?
Factory Ammo. Winchester 9mm.
The trigger let the hammer go before the round was fully chambered and the exposed brass blew apart. The gun is OK but the $475 Fostech Echo Binary Trigger isn't safe to use. I'm tempted to replace it with a cheaper drop-in trigger and then sell it.
a6m5
'22 Ranger XL
Wow. I’m sorry to hear that. Looks like @DocE3Gun was on the money. I wondered about the hand loaded ammo, because I had overcharged factory ammo blow up my HK USP before(in battery). You hear about unsupported ammo out of battery exploding, but didn’t know triggers can be the culprit!
Pic of my USP from few years ago:
