Gray screen. Any fixes?
Mad440x
Michael
East Tn.
2021 ford ranger
Construction. I work!
Screen went gray. 21 with 70,000 miles.
Tom_C
Virginia, USA
System Admin, Retired
Hm. It would probably be hard to repair yourself. If you could get to the actual screen and gently press around the edges you may get it to come back (assuming it's a connection issue), but it would be a temporary fix. My WAG is the screen is bad.
Pull BCM Fuse 13 for a few minutes and reinstall.
Use Scanner and check for any codes, also run IPC self-test with scanner or Forscan
A code will pinpoint issue
