Gone surfing
Ramon Felix
Ramon
Los Angeles
2019 Ranger XLT
Hey bud where did you buy the blank key? I guess im not tasing google the right question because the only thing that comes up is the key less entry key
thank you
Ramon Felix
Ramon
Los Angeles
2019 Ranger XLT
I have an XLT and my local Ford dealer made me a "skeleton key" for only $20!! I leave the original FOB in the truck and put the "skeleton key" in my wetsuit. Problem solved! When you open your truck again, make sure the FOB is close by to quickly disarm the alarm or it will go off.
thank you
Surfink
Casey
2009 Pepper White Cooper S Clubman, 2019 Saber STX SuperCrew
I got mine at a locksmith up the street from Galpin Ford.. $50
I don't remember the name of the shop..
John Lyman
Atlanta, GA
2019 Ranger Sport 4x2 Oxford White
Then it sounds like the solution Surfink suggests is probably the most viable solution in your situation.
As for me I've already ordered a keyless entry pad from Cutter Ford, will probably mount it to the inside of the fuel fill door.
I like the idea of mounting inside the fuel door - we have all those ford pass points - hmmm.......
Mokume
Honolulu, Hawaii
That proposition has turned into an utter fiasco for me, I'll PM you about it, if you like.
The forum members need a break from my rants...
Alex K
Alex
San Diego
Ranger
thank you
As I mentioned in my original post, my local FORD DEALER made it for me.
John Lyman
Atlanta, GA
based on that response I believe I will skip that solution. Sorry for your frustration.
John Lyman
Atlanta, GA
So if you have an Apple Watch you can use that to lock and unlock your truck. Just tested that
John Lyman
Atlanta, GA
The Fordpass app if you have it on your phone will also.
Steve W
True the phone will work. However, if there person wants to leave that also in the truck they can do that.
