Genuine Ford Parts, Accessories & Ford Performance
Hey, I was looking at your site as I tore my front driver CV boot, I'm seeing 2 options for complete axles: with or without tow package. Are the CVs really different? And/or are they stronger?
I think it was confirmed by another member that the - Tow Pack CV Shaft is longer, so yes they are different (lengths) -The Tow Package 2 = (The Towing - Hitch Receiver) not the Bumper & Ball.
So if you buy the cheaper shaft (its shorter) and will create issues, opposite if you do not have Tow Pack 2 - it will be too long.
But I will let Benny confirm it.
I can only confirm that I ran into this issue on a previous vehicle, where the shorter shaft was boxed into the longer shaft box, got into a sharp turn and the shaft made noise - pulled it back apart and with a warranty swap and noted side by side length (off set) by about 1/2 inch.
I am sure the Ranger will show a similar (off-set)
LevittownFordParts.com
Gold Sponsor
Benny
New York
All Ford's
Hi,
We do not have engineering data to compare dimensions. If you need help specifying which part number is correct for your truck please message me your VIN.
Thanks,
- Benny
I completely forgot I did this (research)
Granted this information (Specs) is from Rock Auto, I dug into this last year to find an answer to the question of the different part numbers, I do recall another member having install issues for the shaft (Another Thread - ? on which one it was)
This was posted to this thread
Another CV Axle joint popped out post. Please have mercy I need some input. | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Copy of my post:
Jul 15, 2024
Researched - yes, the Tow Package shafts are longer and have a different (socket size) nut.
Using Rock-Auto (info) specs as a guide and compare the TP vs Non-TP shafts
For the Left Shaft:
Tow Package = 24.21 (in) compressed length - axle nut (socket size) 32mm
W/0 - Tow Package 23.94 (in) compressed length - axle nut (socket size) 36 mm
So, it is possible to ensure you have ordered the correct shaft is to know which size socket fits over the axle nut as a secondary confirmation, not absolute but a secondary way to know which part number you may have installed (if the parts tag is no longer attached)
End of Original Post:
Note: I recently replaced my front shock assemblies and had a 35mm axle nut, I have the Tow Pack 2 package - so for the socket size (above) does not match, so I do question the validity of the information provided by Rock Auto
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
Copy of my post:
Jul 15, 2024
For the Left Shaft:
I also have 35MM Axle nut on a '22 tremor without tow2 package. I kinda looked into this as well, the knuckles are the same and hubs are the same so I really do not understand the length difference and why the longer one would not work on non tow2 package.
LB
San Francisco
2021 Ford Ranger 2021
What a strange change to make, 3/8" longer. I'm curious why they would have made that change. I would have expected maybe a little beefier on TP versions, thought it might be a little strength upgrade to swap in but oh well.
I've had my axles half out before for suspension work, fairly sure it was a 35mm nut but I do not have to towing package.
ControlNode
Eastern NC
Computers
Well, I'm looking for a part: #BV6Z9D289E
EddieT
Ed
Southern California
2021 Ranger Tremor, Subie Forester
Hi Benny -
Trying to figure out the proper TPMS sensor for my 21 Ranger Lariat/Tremor. I'm seeing both TPMS42 and TPMS68 as options and am unsure which is appropriate. Build date is August 21.
  • SKU:HC3Z-1A189-F
  • Other Names:TPMS Sensor, Tire Pressure Sensor, Kit TPMS Sensor, tpms107
  • Description: Continental. To 01/02/2023. Ranger. 315 mhz. From 04/04/2016. Dual Rear Wheels. Aluminum Wheels. Single Rear Wheels. Incl.Cap,Screw and Valve.
  • Replaces:HC3Z-1A189-A, HC3Z-1A189-B, TPMS-42, TPMS-43
vs
  • SKU:TPMS-68
  • Other Names:Motorcraft™ Tire Pressure Sensor, Motorcraft™ TPMS Sensor, Kit TPMS Sensor
  • Description: Bronco. 315 mhz. 315mhz. Ranger. Incl.Cap,Screw and Valve. From 12/17/2020.
Thanks in Advance!
Ed
Gold Sponsor
Benny
New York
All Ford's
Hi Benny -
  • SKU:HC3Z-1A189-F
vs
  • SKU:TPMS-68
Thanks in Advance!
Ed
Hi Ed,
Use the following https://www.levittownfordparts.com/sku/hc3z-1a189-a.html
This is the equivalent to TPMS 107
Please let me know if you have any other questions.
Thank you,
- Benny
Gold Sponsor
Benny
New York
All Ford's
Hi Guys,
I just wanted to take a moment to introduce our re-vamped site, It's very similar to the original but on a newer more modern platform https://www.levittownfordparts.com/
Feel free to kick the tires and fire back any feedback good or bad. Thank you for taking the time to check it out!
- Benny
Muffin1
NJ
Looking for the pair of these side steps, M2DZ16450BC is there a code available?
Thanks.
Tkent
New York
2001 F150 SCAB 4 X 4 2023 Ranger SCAB 4 X 2
Contractor
Hey Benny, any code for engine and cabin filters?
