Garage recommendations
Remix
2020 ranger lariat supercrew
Looking for a garage in the DFW area that can fix my mushy brakes
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Forscan can do it. Google it or wait for someone more knowledgeable than me to explain it. Or go to the dealer it is a warranty issue.
look for the forescan threads and mushy brakes. lots of good info on it and you can easily do it. just to be safe id say check your brake fluid first.
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
Forscan didn't do anything for mine. I mean it made the noises and all but that's it.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Might need to be manually bled as well. Possibly more than once. Dealer can plug in and open up the abs module for a full bleed. Otherwise you will have to do the forscan bleed then a real bleed a few times.
Remix
Do the quick lube spots bleed brakes?
Rinn69
N. Central Iowa
Retired USAF MSgt
Bed your brakes first.... Use the search function to follow the procedure....then bleed your brakes if necessary...
