Scott D
Scott
2020 Ranger XL/STX
That's to bad Chris I can't believe they messed it up, well actually I can. I mean it's a headlight adjustment not a tranny rebuild you'd think they would check it once they're done but I guess now a days that's just asking to much!
While you're at it I would double check the oil drain plug and filter just to make sure they're both tight along with the oil level. If they messed the headlights up no telling what they did on the oil change. ?
This! I won't let anyone change the oil in my vehicles or my wife's vehicle.
I was changing the oil on a fellow employee's vehicle a few years ago and I guess someone in the past had run the drain plug in with an impact wrench, cross threading it as it went.
How inept does one have to be to not be able to handle removing and installing a drain plug?
FoD
Terry
Out There
Retired & Grandparenting 🤣
One could probably create quite the bulleted list of ineptitude in this case (i.e. management, millennials, boomers, tall, short, etc.) :crazy:
Scott D
Scott
2020 Ranger XL/STX
^ Love those stripes.
I installed the Lariat foam engine cover on my STX yesterday.
I had started on installing my FH seat covers, but I had to paint/clear coat the blingy gold logos on the seat backs. I let it dry overnight and maybe I'll put them on this evening. I did them with flat black.
FULLSCALE
Adam
Ontario, Canada
Finally adjusted my headlights down now that it’s getting darker earlier at night and later into the morning. Took longer to mark the garage door using the Ford Performance kit instructions than it did to actually adjust. Not sure why I waited so long... been since March when I installed my Eibach kit that I‘ve meant to do it!
Bproctor
Bruce
Hickory, NC
2019 Ford Ranger Lariat 2WD
NC National Guard
Question. Say someone wanted to swap out the branded fender vents for the non-branded OEM vents. How are they attached? Clips? Are the popped out with a trim tool?
Asking for a friend.
Mine popped off fairly easily using a trim tool. I put a piece of cardboard under the tool to keep from possible scratching the paint.
TVRangerSTX
Trevor
Hitch step
Yeah, I got a hitch step too, but find it's useless to get in when the tailgate damper has let my gate down ever soooooo slowly. I need a step more when the tailgate is DOWN!
FoD
Terry
Out There
My baby!!
Full Raptor Body Kit
20" Rims
Front and Rearlight protectors
Folding Mirror Mod
Forscan Raptor startup / shutdown screen enabled
Forscan Auto Door Lock enabled
Nicely done Robert. Some body here might ask you about a tailgate damper being installed :blush:
peterson1604
Scott
Escanaba, MI
Body shop manager
Removed my running boards for the winter. Storing them in the rafters until spring time. What should have taken 15 minutes took about a half hour because someone wanted to play fetch and kept interrupting me. ?
TVRangerSTX
Trevor
Yup, they are ice collectors in the Great White North. Plus the OEM steps on my '04 Ranger rusted away to ugliness...
There are a few holdouts but you're by far the toughest! ?
