Drivers and Passenger Front Seat Bracket Replacement - 2022 Supercrew
Mark Gale
Phoenix, AZ
2022 Ford Ranger Sport
Plumber
I have not been able to locate aftermarket front seat brackets for my truck. The OEM seats are beat and I want to replace them. Google hasn't been very helpful or may be limited by my poor search ability. I'm looking for an off the shelf solution but would consider a full custom solution.
Thank you!
RangerBill
PA
Thank you!
Not aftermarket, but junkyard?
Superspirit
earth
22 ranger
Go grab used seats from a self serve used auto parts, transfer the bracket done!
ScarzRanger21(2.0)
Eric
Auberry, CA
2021 Ranger 4x4, 2019 Ranger Fx4
Electrician
I’m not finding anything online specific to the ranger, just “universal” seat brackets that probably aren’t universal lol. I would do as others suggested, go pull a couple seats out of a wrecked truck at the junkyard and call it good. Or take a gamble and try one of the universal ones, just make sure you can return it if it doesn’t work.
Thank you!
Define what is worn - the cushions or covers or both, those can be replaced, however the seat tracks incorporate a position sensor (ties into the Airbags) on how far forward or aft the seat is. When I last checked this - there is no aftermarket (direct fit) seats , it would require some custom made brackets, which I recall someone on here making as they wanted the seat to push back farther (If I recall correctly) but they kept the OEM seats.
I would have to (check) to be sure (confirm) that even the manual adjusted seats have the position sensors on the tracks.
If you recall - I spent some time trying to get my cushion, modified so it was comfortable and ended with a modified factory cushion, never really got it perfect but its better than the sagging OEM version. I tried various modifications to the seat base assembly, and to be honest its not fully back together (yet) - been busy with other home projects, just need to (re hog) the cover back on the cushion and secure the clips back on the base.
So your best bet (at this point) if only the cushion and cover is worn - is to only replace them vs whole seat - granted anything's possible just may need to modify the attach points and keep it safety rated.
dozxab
Prescott AZ
Are you thinking of these? My brother put some in his '02 Jeep and I seem to remember them being mentioned here. https://desertdoesit.com/collection...+seat+jacker&utm_content=seat+jacker+-+phrase
