Daytime lights?
Taykel
Ga
2020 Ford Ranger XLT 4x4 Crew Cab
Self Employed
In the settings tab under lighting there is a option for daytime lights. I have mine checked . But they are not on. Is there something I’m doing wrong or why’s the deal with this light setting?
geophb
Mechanical Engineer
You have autolamps on? Manual hints at that DRLs only work in autolamp setting.
weasel1
Derek
Pembroke, Ontario
Nuclear Operator
Park your truck facing a wall. Put your for on the brake and out in gear and then check. Drl's won't come on in park regardless of settings.
Taykel
Taykel
Ga
Self Employed
Right I’ve done that nothing.
do drls work only on auto lamp?
Taykel
Taykel
Ga
Self Employed
Yes. Only auto.
Quote from manual
"The other lighting control switch positions do not turn on daytime running lamps."
Thank u I will go give it a try
Taykel
Taykel
Ga
Self Employed
Just walked out side and checked them. From y’all’s advice bam daytime lights are working.
thank y’all so much!!!
weasel1
Derek
Pembroke, Ontario
Nuclear Operator
Yes. Only auto.
Quote from manual
Just wanted to add to this... The above does NOT apply to Canadian Rangers. As soon as I take my truck out of park, the DRL's are on regardless of whether it's in auto mode or not.
geophb
Mechanical Engineer
Interesting. I wonder why?
Just went out and checked mine to make sure I am not losing it, and it performs the way the manual states. (i.e. drls only come on in autolamp)
I believe DRLs are mandatory in Canada. Can't turn them off.
weasel1
Derek
Pembroke, Ontario
Nuclear Operator
Correct. It used to be that every vehicle had to come with them installed, but it wasn't mandatory that they work (unless you had to safety the vehicle). I suspect that's not the case now.
Yellowtoy
Australia
2019. Ranger Wildtrack
Crane Operator
Same in Australia , mandatory on..
VAMike
2019 Ranger Lariat SuperCab
maybe people in canada and australia are better at figuring out that they're driving around without their headlights on at night :crackup:
