Cracked Control Arm Bushing
I have a 2021 Ranger FX4 with only 26,000 miles. The rear end recently started making a loud squeak with each wheel rotation (see video). I took it to the local Ford dealer and they reported a cracked control arm bushing. They also reported a twisted leaf spring which was not causing the noise but needed to be urgently replaced. They wanted $2750 to replace both parts.
Does this sound legit? When I think control arm I think front end, but the noise was coming from the rear end. Also, is a twisted leaf spring an urgent replacement or can an indy repair it for cheaper? I don’t mind paying the dealer a little more to make sure things are done right but this seemed pretty steep given the truck’s low mileage.
Thanks in advance.
4x4 Ranger Man
Ben
Houston
2019 Ford Ranger Lariat
Port Engineer
I'm not sure how a control arm bushing would cause what you are hearing I would be more interested into how you got a "twisted leaf spring" this might help explain the noise you are hearing.
These are the photos they provided of the leaf spring. The roads are terrible in my area so I see a lot of potholes but I’ve never done any off roading or anything.
4x4 Ranger Man
Ben
Houston
Port Engineer
I live in Houston so I see many potholes and I off-road some too and I don't think a pothole did that did you hit something?
4x4 Ranger Man
Ben
Houston
Port Engineer
I would be willing to bet the bad bushing is on the same side am i correct?
4x4 Ranger Man
Ben
Houston
Port Engineer
I am not talking about hitting a vehicle, I would bet you hit something in the road or someone driving your truck did and not tell you.
4x4 Ranger Man
Ben
Houston
Port Engineer
And the sound you are hearing I would bet it is the brakes and they too have been tweaked by what was hit.
It's possible but I am the only one who drives the truck and I don't remember hitting anything recently, which is when the noise started. Dealer did not report any issues with the brakes. In any event, if I am going to pay close to $3k for the control arm and leaf spring it better fix the noise issue.
4x4 Ranger Man
Ben
Houston
Port Engineer
Good luck but I am puzzled as to the noise it is making as neither of those I would think would make that sound It sounds like something is rubbing to me but looking at the caliper and rotor it is hard to tell. I would think you would well know when you did hit something to do that kind of damage. That is why I said maybe someone else was driving.
fjwlobo
Fred
Brooklyn Park, Maryland
2020 Ranger Lariat FX4 SCREW
If you're going to replace the rear leafsprings, I wouldn't replace them with the factory leafsprings. Do yourself a favor and get a multileaf. Cheaper and your ride will definitely improve.
I have the Icon. Do some research for yourself and get the ones that you feel will work best for you.
Cabose-1
Eli
Student
My 2022 ranger had a pair of leafs like that on the driver side. Never caused problems, towing or working. Or made noise. Traded it after 60k miles. For a Ranger.
To me the noise sounds like a pebble is stuck between the rotor and backing plate
JoeDop1
Mojave Desert
2020 Ranger Lariat FX4 Crew Cab
Retired engineer
Agree with @airline tech. Jack up that wheel off the ground and rotate it. you'll likely hear where the noise is coming from. My driver's side leaf-spring looks the same. I've had no problems or noise to date.
