Clicking Noise Under Steering Column
CLopey
Christian
Los Angeles
2019 Ford Ranger XLT
Coach
Hey all,
I just noticed this clicking noise coming from under my steering column a few days ago, had never heard it before.
I’ve attached a video, hopefully the audio is okay.
Any help?
Zappy
Tom
Minnesota
The Vent Box issue perhaps? Does the temperature change when you go from hot to cold?
CLopey
CLopey
Christian
Los Angeles
Coach
Hey Zappy, thanks for the reply. Can you clarify what you mean exactly?
Zappy
Tom
Minnesota
You bet. I had these clicking noises from inside the dash, after I shut off the vehicle, about two years ago. In addition, it seemed when I changed from hot to cold (or back), the vent system would take several minutes to respond. Soon after, it was always stuck on hot. One of the many threads for this issue is here:
https://www.ranger5g.com/forum/thre...h-clicking-snapping-noise-from-the-dash.9659/
The noise in your video sounded familiar so I figured I'd mention this as a possibility.
It's most likely your assigned Truck Gnome dancing inside the dash......
Each Ranger gets one permanently assigned as it rolls off the assembly line.
This is a rare photo of one....you can see how small they are.....they fit anywhere....
CLopey
CLopey
Christian
Los Angeles
Coach
Aahh gotcha. Thanks for clarifying and sharing that thread. Hopefully I can get to the bottom of it.
CLopey
CLopey
Christian
Los Angeles
Coach
I think I’ll name mine David.
Kemo Sabe
Kemo
Upstate SC
Hey all,
Any help?
Blend door. Mine is the same, and it seems a reoccurring Ranger problem.
55,000 miles here.
does the extended warranty cover this problem?
mrmike7189
2024 ranger STX 4x4
either that or a Pukwudgy
