- First Name
- Steve
- Joined
- Jul 1, 2021
- Threads
- 84
- Messages
- 5,865
- Reaction score
- 29,227
- Location
- Fishersville, Va.
- Vehicle(s)
- Previous 2021 Ranger, Now 2019 Ford Expedition
- Occupation
- Navy Vet., Retired Police Sgt., Grumpy Old Senior Citizen
I think you'll like them. They make a huge difference when towing, especially if you have a standard 8 foot wide trailer.I got my new set installed. Took about an hour and half with a 15 minute toddler potty break and other various toddler stop work issues.
I used a T30 L torx wrench and only removed the tweeters. I figure the majority of my time was taking off and putting on the bottom bolts 1/4 turn at a time. I also replaced 2 out of 3 bolts with hex bolts M6x 18 and a fender washer. I didn't have a socket or wrench small enough for the third to be replaced as well.
Biggest issues is starting the bottom bolts getting them lined up, etc. On my passenger side unit the plug connector pushed 1/4 farther into the truck. Not enough to plug or cause issues other than making that bottom bolt that much harder.
Also there is a rubber gasket on the tweeters snap cover that is now inside my door along with a fender washer.
Not sure if I should worry about the gasket.
I pulled my door panels off, made it easier....but, like you, I also replaced the torx with stainless hex bolts and appropriate washers.
Their going to be very "stiff" and hard to pull out at first, but the more you use the, they'll become easier to pull out.
