Check Park Aid
hoodstrings
united states
2019 ford ranger xlt
First, all parking sensors are clean and free of debris. Triple checked. Issue started out of nowhere. “Check Park Aid” alert shows up on dash every time I shift out of park and the truck with a red “!” Appears on the infotainment screen. None of the park aids work now. Hooked up to Forscan and all 8 sensors show circuit short or open to ground (picture). Anyone have any clues on where to start with this?
seasprite
Missouri
2022 Ranger XL STX
I bet you have some green crusties somewhere on the harness or damaged wires.
I would start at the sensors and work my way back looking for damage. Or try to find a wire schematic on this site. It has a lot of good info.
RangerBill
The only thing that I see that is common to all 8 parking aid sensors is the BCM (body control module). The PAM (parking aid module) is contained within the BCM. I would check the connectors to the BCM (contains fuses under the driver side dash). Connector C2280E has the 4 rear sensor wires. Connector C2280C has the 4 front sensor wires.
I would also reset the faults and see if they return.
hoodstrings
united states
I’ve done a quick scan. Almost impossible to trace the entire length of the truck. I’ll check for a schematic. Thank you
hoodstrings
united states
Good suggestion. I’ll see if I can find those connectors. Thank you
Have you tried cycling the switch on the console?
I would start there
This one may be tricky to isolate as there are 2 separate circuits, I would have to hook up and view the live data PIDs to see if I can find something for you to look for.
It is possible that a single sensor is taking down the system.
To help isolate:
With codes cleared and in (Park)
What happens when you cycle the switch, does the system Enable and Disable?
You state when you move out of Park it faults, is this both Reverse & Drive?
You may try to isolate Front & Rear, via the switch
Clear the codes -Place in Reverse - Does it Fault?
Clear the codes - Cycle the switch to disable, place in drive and then cycle the switch to enable.
Does it fault?
Just a thought on how to possibly isolate the Front or Rear as you must pass through Reverse to get to Drive.
Other Possibles.
Disconnect C405 - This is the Rear Bumper Harness that feeds all 4 Rear Sensors, clear the codes and note do the front sensors work in Drive or do they still fault.
Disconnect C145 - Note this one, I am not sure on access without pulling the Front Bumper (trim) off. (This feeds the Front Bumper Harness)
Do the same as you did for the rear sensors, clear the codes and place in Reverse, do the Rear Sensors Work or do they still fault.
This is just a way to possibly isolate a bad sensor shorting the complete system.
There is a - Logic Ground for the PAM and that is G301 - Location is listed as under the driver's seat, I do not have a pic of the exact location at the moment, but I suspect its under or near the door sill cover.
This is a ground point for the door lock / unlock relays, so if the door locks are not functioning correctly - this would be a good spot to check as well.
Hopefully the above will help in isolating the issue, post your results and we can dig deeper if needed.
hoodstrings
united states
To help isolate:
Does it fault?
Other Possibles.
Thank you for the detailed response. Unfortunately, I don’t always have access to Forscan. I’ll see what I can do with the connectors and such in the meantime.
Deleted
None
Please keep us updated on the situation and results, I also have the same issue and have not dug into as of yet. This post and the replies have been awesome. Thank you ??
Clantz86
Nova Scotia, Canada
2021 Ford Ranger XLT Tremor
I'm also dealing with the same issue on my 2021 Ranger. No DTC's, just a the generic "Check Park Aid" warning that constantly pops up after taking the shifter out of park after every start up.
I'm going to check through all of those connectors tomorrow and see what I can find. Huge thanks for the information that's already been posted!!
hoodstrings
united states
Found some diagrams. Checked the grounds but they all look brand new. Connectors look fine. Fuse 62 doesn’t make a lot of sense in this context. Book says for BCM lighting of the left side. Fuse 67 is same for right side. All lighting is fine. Starting to think the PAM is cooked unless anyone has any better conclusions
jovey70
Josh
Southwest Michigan
2021 Ford Ranger Lariat
EHS Manager
Same issue here so watching thread. no forescan or scanners and am not a Tech or even an electrician by any sense of the imagination but i am following and will look at all connectors mentioned. I've heard there is a connector behind the drivers side front head light that should be checked for a bad pin.
I think this tread had some posts dumped with the recent server issue.
I am trying to remember what I posted (lost posts)
First - The Parking Assist circuit does not have a separate fuse of its own, its a shared power feed via Fuse #62
EDIT: This would be the switch power & integral light only
The PAM is incorporated into the BCM, integral part of it
To truly T-Shoot the circuit, you need to have a scan tool, to either check for codes or view Live Data (PAM) PIDs to see what the circuit is doing - view each sensor input and your Sync display may give some direction for Front or Rear - key questions are when does it fault (Reverse / Drive or Both)
When the parking aid is displaying and you are in a known (All Clear) position - what color are all the sensors (both inner & outer) on the screen.
The issue is pinpointing down which of the 3 circuits are picking up the fault.
The switch circuit, power from fuse #62 and ground to G302 - under the passenger seat
The switch circuit gives the Enable/Disable signal to the PAM module and when disabled the switch should light up. (Center Console) the switch controls both front & rear.
EDIT: I should point out that the manuals do not specify in detail this important piece of information but it is briefly mentioned in the T-Shoot fault trees that the (BCM-PAM) power outputs to the sensors is a 5-Volt (VREF) circuit, the switch circuit is not VREF. So this would truly explain why a single sensor can take out the whole circuit, its being pulled down.
So what is not shown on the wiring diagram is where the BCM is suppling that power source from and more importantly that it is a VREF circuit.
I looked deeper into this to confirm if (Fuse #62) was providing the power internally as I thought at first, after a deeper look I discovered that the BCM - PAM is feeding a 5-Volt VREF on the circuits.
The Front sensor circuit - Power feed from the PAM (itself) and ground (sensor ground) via internal PAM logic to G301 (Logic Ground) -The actual ground to the structural body.
So it is a single sensor ground feeding into the PAM from all 4 front sensors via a spliced circuit.
Power Feed is also a shared power feed from the PAM to all 4 front sensors
Ref: Wiring Diagram Above:
C2280-C Pin #7 - Power Feed (Front) the internals use the LF Inner Sense circuit logic to power all 4 sensors.
C2280-C - Pin #35 - Ground feed into the BCM (PAM) for all the front sensors, that ground is internally spliced circuit and exits from C2280-F - Pin #6 (Logic Ground) runs to G301.
The Rear sensor circuit is the same operation, except uses different pins on the connectors
C2280-E - Pin # 26 - Power feed for all 4 rear sensors
C2280-E - Pin # 27 - Sensor ground for all 4 rear sensors - feed into the BCM (PAM)
This is also internally spliced and exits C2280-F - Pin #6 (same as above)
So if we look at the circuit and note that the sensor grounds are spliced internally inside of the BCM (PAM) then if any of the 8 sensors on the truck are shorted (or the wires feeding them) could cause on issue on the complete circuit as all of them would see the short.
Now for the switch side of the circuit - note that the Parking Aid system is always working and operational, the switch only disables the (indication) to the Sync Display with that knowledge you can - note the switch light (not the background light) - when its cycled does it light up?
EDIT: One operational note - At engine start the switch (off) light should remain off, the manuals do not cover this either, but I think if the system has a fault the (OFF) light will be illuminated.
Some vehicles perform a self check of the circuit at key cycle and momentarily illuminates the (OFF) light- the Ranger does not, so it should remain (dark) if no faults are sensed.
The switch is also like the (ASS) switch, it must be cycled to (off) at every key cycle to disable the indication - it defaults back to enabled when the key is switched to off - (If you wanted to keep the indication disabled)
Inline connectors for the circuit:
Switch Circuit: C311
I do not have a live pic of this, but it is the next connector (upstream) of the console switch located under the console area and near proximity of the switch, it may run back vs front (IDK) of the actual switch location. (diagram is not clear enough)
Front Circuit:: C145
Rear Circuit: C1147 / C422 / C405
Another test you can do without a scan tool and this would possibly isolate which sensor is faulted - perform this in park (if I remember correctly) before you shift out of park, I think the sensors will be receiving power - get into a quiet area and place your ear near each sensor you should hear a (vibrating pulse) making a recording with your phone will enhance the noise.
EDIT: I did confirm that all 8 sensors are receiving power and will produce the (vibrating pulse) regardless of the switch position, so this confirms that the switch will only deactivate the indication part of the circuit.
The above only covers the Parking Sensor circuits, however if the PAM has lost a communication signal on the Can Bus between various other modules will also trigger the system to fault.
Being that most report (no codes) I suspect that the code is clearing itself - so you will need to get the truck set-up to get the code active (Drive or Reverse) and have the scan tool plugged in with the message active - then scan for codes or view live data of the PIDs and note any discrepancies.
The reason for the importance of this is the (Gear Position - Input) data message on the Can Bus and the circuit is only seeing the fault at that time as that is when it looks at gear position and vehicle speed inputs and triggers the APIM (Sync) to display the screen, it registers the fault and then the message generates.
Key Point - The message might need to be showing in order to pick up the specific code that is producing the message.
I hope the above helps give some T-Shoot points
Note the only thing I left out is the BCM Connectors that are listed on with Wiring Diagram from post # 13.
Those can be covered in a full on wire T-Shoot if needed, but again its best to use the fault code and or live data as a guidance to isolate down where in the circuit the fault lies vs blindly testing the whole circuit - Time Consuming
EDIT:
To intertwine my posts from another thread and bring all the info into this thread from May 2025.
Sound Recording of the Park Aid Sensor - (Pulse/Vibrating)
And Live Data PIDs for the Sensors
Note: These readings are with (no obstacles) near the sensors
Front:
Rear:
System Status:
