Charging Sys-Full Description-Trigger Voltages-Test Results
RangerBill
PA
@airline tech
Where does the reference line generator desired voltage come from ?
This infernal engine cut I'm getting , relates to intermittent voltage cut on ☝🏻☝🏻☝🏻 that line
What exactly is happening? Any DTC codes?
colin39
Colin
Y-uk
3.2 ranger with issues
Mechanic believe it or not
The PCM (Powertrain Control Module) controls the charging voltage via the LIN communications link. See diagram.
Is there anyway I can upload a video
colin39
Colin
Y-uk
No codes , this thing I love but it's cost me a fortune chasing this throttle cut fault
colin39
Colin
Y-uk
RangerBill
PA
What throttle cut fault? If you described it earlier in the thread, I missed it. How is it related to the battery charging system?
colin39
Colin
Y-uk
Ok I run a 3.2 diesel with a 6r80 box , it started throttle cutting and calling for neutrals march time, no codes 🤷🏻 I've narrowed it down to this it kills the voltage and shuts the pcm
colin39
Colin
Y-uk
@airline tech bill take a look please you are the only person on the web to mention generator desired line
Thank you 🙏🏻
RangerBill
PA
Thank you 🙏🏻
I added a description of operation of the charging circuit in my post above with the wiring diagram. I doubt that the charging circuit is causing that. Is your battery voltage in range of 13 - 15 volts?
I couldn't make out anything on your shot of the scan tool. Is the battery symbol coming on just as your engine cuts out? Check power with a voltmeter to the PCM to see if it is losing power. That would cause issues with the engine and battery charging, since both are controlled by the PCM.
colin39
Colin
Y-uk
I have a better video, it's shorter but there is and issue with copyright , radio was on 😂🤣
Today is the first time I've had the battery light flash.
I've also changed the alternator
I am working on a T-Shoot, but I have a question.
If you stay off the throttle - does it, do it?
I suspect either the voltage is dropping off the PCM or a input / output is shorting the PCM and trying to deduce if the Throttle Body or Accelerator Pedal in / out circuit is shorting the PCM out.
I agree the PCM Control module voltage drop is causing the Generator Desired to drop out.
Its defiantly a short or power loss issue, it may be difficult to locate without a code.
It could be the alternator itself or the PWM (control) feeds to it - shorting out as well.
colin39
Colin
Y-uk
colin39
Colin
Y-uk
I've changed the throttle peddle and throttle body , tested all the wiring to n from both items and the alternator, the UK only uses a 2 wire unit b+ and a signal to the alternator which is only 8 volts at ignition.
It only fails under load and once hot, today I drove for 3.5 hours before it cut on a junction and nearly killed me. 3 garages have had it and changed all sorts but no fix.
I'm a 38year in the trade spinning spanners kinda guy but I'm at a loss and ford won't help with the wire information regarding that gdv line
RangerBill
PA
Monitor the voltage feed to the PCM and see if it loses power when the issue occurs.
colin39
Colin
Y-uk
On it in the morning , thanks for your brain buddy.
RangerBill
PA
I don't think it's the alternator, but you could unplug the LIN connector to it and eliminate that as causing your issue. With it disconnected, the alternator should default to a fixed voltage output.
