Blacked Out Appearance Package Thread!
paval3
Val
Pennsylvania
Hi Val.
Edit: Never mind, I thought you were looking for the fasteners that mount the bracket to the vehicle.
My Ranger did not come with the front license plate bracket (wish it had) and I wanted to add a grill insert that uses the holes and fasteners for the license plate bracket. I tried a couple of dealership parts departments, and the fasteners were not available. FYI they are M6 x 20mm bolts. Ford part number W714810. I found some M6 bolts at the parts store that I used, but not black, which woulda been nice. They seem to be working fine. Good luck.
I went to Autozone and got a pack of black license plate screws. They worked for fastening the novelty plate on the OEM front license plate bracket. I wanted a flat clear cover for over it and bought the thinnest one they had, but together with the novelty plate, they wouldn't fit down in that little slit I circled in orange in the photo. So I ended up just having the novelty plate. Sorry pic isn't better, Sun was making grass reflect onto the plate.
NickTheEnforcer
Anthony
Northern Illinois
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
Same problem but I am going to cut the tabs off
CaliBee
2021 Ranger SuperCab XLT FX4 Cyber Orange
Retired Software Engineer
Cyber Orange with the black appearance package. I like the 18" wheels, even if they're not preferred for serious off-roading, I think they look great.
paval3
Val
Pennsylvania
It looks like you would also have to drill holes through the OEM bracket for 2 bottom screws if you want to put on a clear plate cover. Am I right??
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
Sure looks that way
Hi Val,
When faced with problems like this it can be puzzling. What I would try is abrading away the back side of the tab so a protective cover fits. This can be accomplished with a bit of effort and if I was on the road, and not my shop, I would use the rough side of a nail file to thin the tab. I have a package of nail files in my shop and use them all the time as they are disposable and work well. Sometimes you can use a hacksaw blade to do this or a toothed handsaw, followed by the nail file. Best to find a way to secure it to a work surface...use a double sided tape works well on a good work surface. I think with a bit of patience and time you can get your protective cover to work.
Good Luck with your project!
best,
paval3
Val
Pennsylvania
Hi Val,
best,
Thanks for that suggestion. I just left the plate bare. If I tried to get the bracket off or tried to file anything while it is mounted.... knowing me I'd scratch something.
