MST Overland
- First Name
- Matthew
- Joined
- Mar 8, 2021
- Threads
- 4
- Messages
- 14
- Reaction score
- 35
- Location
- Livingston
- Vehicle(s)
- 2020 Ranger XLT FX4
- Occupation
- Attorney
- Thread starter
- #1
Given the high cost of full rack systems and the lack of availability of simple mounts on the market, I fashioned my own by having someone bend a 5.5" plate of 3/16" steel at a 41 degree angle at the 3" mark. Countersink the bottom for M6 flat head bolts and purchase two new 5/16-18 2.5" bolts to replace the original cleat bolts. I used 1/4" neoprene rubber between the mount and Diamondback for dampening purposes and to allow some space for the countersunk bolt heads below. It is rock solid. I may use the existing bolts to attach some 80/20 track between the two plates to allow me to carry more bikes using the same fork mounts and t-slot nuts.
But for now, this is the cleanest solution I could find. A simple bungee to the rear cleat is all you need to keep it from bouncing around or side to side. No rear tray is necessary when using a fork mount. Simple yet strong.
