Bambi mode
Not kidding, I've had more medical shit happen to me in the last 2 years than the previous 65.
LOL same here man...ooof...
Here
XLT
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Great - just what I needed to hear as I‘ve begun the task of filling out the forms for pensions and entitlements to start after the dreaded milestone in November. :(
Some of us have started the downhill medical slide long before retirement age. I have waaaay too many doctors to see on a regular basis anymore.
dozxab
Prescott AZ
wait, what?
Now i need to find out how to do this. I would really like that. LOL. Here we go on another rabbit hole.
Another option. " Lasfit LDplus series led H8/ H11/ H16 switchback bulb with a brand new appearance provides a unique way to upgrade your vehicle's lighting. 2 Modes Switchback-3000K yellow/6000K white light increasing overall visibility and road illumination in rainy, snowy, harsh weather. " https://www.lasfit.com/products/ld-series-h8-h11-h16-led-fog-light-bulb?variant=28514963226708
Motorpsychology
Prescott, WI
Vagabond
Seriously. Time flies as I also retired, started SS, busted up my knee and got a concussion, both while skiing.
Time flies like an eagle
Fruit flies like a banana
There is a fine line between being committed, and being committed.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
wait, what?
So, I know I must have read about it here:
https://www.ranger5g.com/forum/threads/forscan-crowdsourced-wiki.2008/
That said, my only notes on the change are here:
"Daylight running lamp set to fog light (top of BCM set to all options),
switched low beam to fog light."
Hope that helps, I wish I had the time to get it connected again and verify it but time it tight right now.
Here is my breakdown of all the lighting (As-Built) Change Notes
Copy & Paste from another thread for the headlight swap
The settings required to swap from Halogens to LEDs (Factory) As-Builts
to match the Factory Settings.
Most of these settings can be found in the Easy Menus
DRL DTC Inhibit LF & RF DRL & Position Lights
726-24-01 - 0000-00C0-D0E2 (Halo)
726-24-01 - 0000-0000-D022 (LED) -xxxx-xx0x-xxxx
0=Normal - All (4) Lights
C=Inhibit (Inhibits only the DRL) Lights-Position Lights Normal
Frequency Select
726-26-02 - 0000-0002-0057 (Halo)
726-26-02 - 0000-0001-0056 (LED) xxxx-xxx1-xxxx
0-Type (0) LED - 1=Type 1 (LED) 2-Type 2 (Halo) 3= Type 3
Moves the DRL from Low Beam to (Dedicated DRL Circuit)
This automatically changes 726-50-01 to (108E) 10 = Dedicated DRL
When (Dedicated DRL) is selected it Powers Pin #6 at the Headlight assembly
VRMS Target Select Configure
726-29-01 - 0000-0000-0259 (Halo)
726-29-01 0000-0000-0158 (LED) xxxx-xxxx-x1xx
0= Type (0) LED - 1=Type 1 (LED) 2=Type 2 (Halo) 3= Type 3
This ties to 726-26-02 (Power Output) and they need to match
Note: This does not auto-change when the above 726-26-02 is changed
DRL Lamp Mask Configure
726-45-01 0A01-0200-0080 (Halo)
726-45-01 0A01-1000-008E (LED) xxxx-10xx-xxxx
01=DRL (Disable) -02=Low Beams - 04=Front Fogs - 08=Front Turns 10-Dedicated DRL 20=Hi Beams
40=Low Beams +Dedicated DRL 7F= (All of the above options)
This allows + additional DRL options (if desired) if none leave this as (10)
DRL Lamp Configure
726-50-01 0280 (Halo)
726-50-01 108E (LED) - 10xx
01=DRL Disabled 02=DRL Low Beams 04=DRL Front Fogs 08=DRL Front Turn Lamps 10=Dedicated DRL 20-DRL Hi Beams
40=DRL Low Beams +Dedicated DRL
This ties to (what is the main DRL Circuit and this also applies Power to (Pin#6) Dedicated DRL Circuit (10)
LF & RF DRL Circuit Configure
726-61-02 - 1600-0000-01A7 (Halo)
726-61-02 - 1601-0100-01A9 (LED) - xxx1-x1xx-xxxx
0=Not Used 1=Used
This setting changes between (Halo & LED) as the DRL has been moved
END OF REQUIRED SETTINGS
Extras: (Optional Additions) for Lighting Settings
FOGs on Turns
726-26-01 - 0100-0003-0058 - xxxx-x1xx-xxxx
0=Disable 1= Enable
This allows the FOG's to be cornering lights on turns
DRL Include Park Lamps
726-26-02 - 0000-0002-0057 - x1xx-xxxx-xxxx
0=Disabled 1=Enabled
This will allow (Side Marker & Taillamps & License Plate Lights) On with the DRL's
DRL (Switchback) w/Turn Signals
726-26-02 - 0000-0002-0057 - xxx1-xxxx-xxxx
Front Fog's with High Beams (Bambi Mode)
726-27-01 - 0100-0001-0057
0=Allow 1=Inhibit
DRL With Fog's
726-71-01 - 0064-0A00-000D - xxxx-xxxx-x0xx
0=Allow 1= Inhibit
Canada (Lighting Settings) - Noted Differences Between the US & Canada Version for DRL Lighting
As I was curious and also T-Shooting on how to get the DRL's on (Always) and what Ford did for
the Canada Law Change in Sept 2021.
Canada BCM Changes:
Feature Configure DRL by Auto Lamp Person 1-4
726-16-02 - 0202-0202-024F (Canada-LED) x2x2-x2x2-xxxx
726-16-02 - 0101-0101-014A (US Version)
0=Disabled - 1=Enabled - 2=Inoperative
This Disables the IPC (Selection) Input from the IPC Menu
Feature Configure DRL by Auto Lamps Vehicle
726-16-02 - 0202-0202-024F (Canada -LED) xxxx-xxxx-x2xx
This Disables the IPC (Selection) Input from the IPC Menu Note: When you DE-SELECT the DRL Lighting in the IPC Menu this changes to (1) from (0) Enable to Disable Canada (Removes) This Input and the Menu as well.
Feature List to BCM (DRL) by Auto Lamp Initial Value
726-21-01 - 1401-0001-0267 -(Canada-LED) -xxxx-xxxx-x2xx
726-21-01 - 1401-0001-0166 (US Version)
0-Disabled - 1=Enabled -2=Inoperative
This Disables the IPC (Selection) Input from the IPC Menu & This sets the (Default) value
for the above - (726-16-02)
726-24-01 - 0000-0000-D022 - (Canada -LED)- xxxx-xxCx-xxxx
726-24-01 - 0000-00C0-D0E2 - (US Version (Halo)
726-24-01 - 0000-0000-D022 - (US Version - LED)
0=Normal C=Inhibit
So, this stays the same if you have LEDs
726-26-02 - 0100-0001-0057 - (Canada -LED) - x1xx-xxxx-xxxx
726-26-02 - 0000-0002-0057 - (US Version (Halo)
726-26-02 - 0000-0002-0057 - (US Version (LED)
So, Canada (REQUIRES) this addition
VRMS Target Configure
726-29-01 - 0000-0000-0158 (Canada -LED) - xxxx-xxxx-x1xx
726-29-01 - 0000-0000-0259 (US Version - Halo)
726-29-01 - 0000-0000-0158 (US Version (LED)
DRL Options
726-45-01 - OA01-1000-008E (Canada -LED) - xxxx-10xx-xxxx
726-45-01 - 0A01-0200-0080 (US Version (Halo)
726-45-01 - 0A01-1000-008E (US Version LED)
So, this stays the same if you have LED's
DRL Lamp Configure
726-50-01 -108E (Canada -LED) - 10xx
726-50-01 -0200 (US Version (Halo)
726-50-01 -108E (US Version LED)
DRL Lamp Circuit Configure
726-61-02 - 1601-0100-01A9 - (Canada -LED) - xxx1-x1xx-xxxx
726-61-02 - 1600-0000-01A7 - (US Version Halo)
726-61-02 - 1601-0100-01A9 - (US Version LED)
DRL W/Fog
726-71-01 - 0064-0A00-010E (Canada -LED) xxxx-xxxx-x1xx
726-71-01 - 0064-0A00-000D (US Version Halo)
726-71-01 - 0064-0A00-000D (US Version LED)
0-Allow 1=Inhibit
Canada is set to (Inhibit)
Canada IPC Changes:
DRL Screen (Option) DRL Lighting
720-02-01 - 4DA5-345D-1ECB -(Canada LED)- xxAx-xxxx-xxxx- DRL Screen / xxxx-xx5x-xxxx
720-02-01 - 4DE5-343D-1EEB - (US Version)
E=Enabled A=Disabled -and 3=USA 5=Canada (Country Code)
This disables the IPC Menu selection from the screen from showing. I suspect if you leave this and with the associated (BCM Changes) the selection will be greyed out.
So, all Ford did was Force the (Park Lights) to be included with the DRL lights and eliminated the
(Auto-Switch) function of the DRL's and also eliminated the (user) control to turn them off.
awd.nv
Anthony
Las Vegas, NV
Computers
Frequency Select
DRL Lamp Configure
0=Not Used 1=Used
FOGs on Turns
0=Disable 1= Enable
0=Allow 1=Inhibit
DRL With Fog's
0=Allow 1= Inhibit
Canada BCM Changes:
0=Normal C=Inhibit
DRL Options
DRL Lamp Configure
DRL W/Fog
0-Allow 1=Inhibit
Canada IPC Changes:
Ok so now you are making me want to take out my laptop to my truck. The Fog with turn signals. I presume it will flash with the signal or?
I have LED fogs installed, set them to be my DRL. Not sure how this will work, if you have the experience, curious.
Thanks for sharing as you usually do!
Fogs on Turns = Cornering Lights
If Fogs are not on - you can turn the steering wheel (angle?) I do not remember exact angle but the Fog will light up (Left or Right). I have mine set to enable and they are only active below 30 MPH if I recall correctly.
It does help in lighting a dark corner turn.
Fogs will not flash with the turn signal - if that's what you thought it was.
Spacenut
Michael
Great Lakes
2021 Ranger Tremor
I had the fogs with turn and did not like it. They come on with the turn signal and also with about a quarter turn with the steering wheel, which was annoying to me.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Well I could right now, but my wife keeps booking cruises, and anyhow I like my job, and they like me, and keep asking me to stay a bit longer every time I threaten to retire (it's a great way to get what you want sometimes), but I guess one day something will trigger it, and I'll just say "thats IT"
awd.nv
Anthony
Las Vegas, NV
Computers
Ahhh ok, yeah I thought that maybe they would flash with the turn signals. No worries. I have thought about trying LED turn lights, I make this u-turn to get home and half the time it seems people at the stop sign don't realize I am going left.
I cannot confirm the Halogen Assembly turn LEDs are brighter but can confirm the LED housing LED bulb which is turn only is BRIGHT and gets attention. It’s bright enough to reflect off of stop signs etc.
