Dgc333
- First Name
- Dave
- Joined
- Aug 24, 2021
- Threads
- 17
- Messages
- 1,742
- Reaction score
- 4,112
- Location
- Massachusetts
- Vehicle(s)
- 21 Ranger Lariat
- Occupation
- Engineer
If the Autowbrake uses an accelerometer to sense the tow vehicle is braking then it would work with AEB.Can someone confirm the autowbrake will not work with the Ford AEB?
From my understanding the autowbrake is a gyroscope and accelerometer that senses that you are braking, like a surge brake, and would apply trailer brakes if AEB were to activate, unlike any other trailer brake controller.
If surge brakes are compatible with AEB I’d think the autowbrake would be also?
The reason a conventional brake controller does not work with AEB is the controller is wired to the brake light switch on the brake pedal. During an AEB event the pedal switch is not activated so the trailer brakes are not activated. The Ford system is tied to the brake lights that are activated by the AEB system, that is why it has the second Lumen module that tells the controller the truck is braking.
