Auto S/S vehicle setting doesn't respond
jhh343
2022 Ranger Lariat Tremor
I hate the auto S/S feature on this truck. I have a lariat and I can go into the vehicle settings on the gauge cluster and turn it off. There is also the physical button by the gear shift I can press. My issue is that the setting in the gauge cluster doesn't matter. I routinely set that to off and I will see my engine stop at a light or something only 5 minutes later. Every stop is a bit of a mystery as sometimes the engine stops and sometimes it doesn't. The A with a circle around it on the dash to show if the feature is on or off will alternate as well. If I press the physical button it keeps the auto S/S off every time, but I have to do that every time I turn the car on. Am I missing something or is this a bug? Why doesn't the electronic setting stay in place?
WingShot
Andrew
Denver, CO
2021 XLT, Tremor, Cactus Gray
Graphic Artist
It will default back to "on" whenever you restart the vehicle. I don't believe there is anyway to turn it off permanently in the regular vehicle settings. Get used to hitting the on/off button, putting it in Tow mode, or put a cheap night lite in the plug in the back seat. Or Forscan?
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
The setting you are changing in the cluster is NOT for the Auto-Stop/Start. It is to disable the auto shutoff at whatever the timeout interval is if the vehicle is left idling. Ways to disable the A/S/S is to press the button each time you start the vehicle, disable it permanently in Forscan, or buy an aftermarket product that will remember the last setting of the A/S/S.
Living The Dream
sandog
Arizona
2019 Ranger XLT Crew Cab Hot Pepper
My A/S/S never activates and turns the engine off unless I mash down the brake pedal.
If I roll up to a light that is about to turn green, just apply enough brake pressure to keep you from creeping forward and the A/S/S will not turn the engine off.
If the stop light ahead of me has just turned red and it looks like I'll be sitting there for a couple minutes, I push harder on the brake pedal and the engine turns off.
I've done a dozen changes thru Forscan but turning off the A/S/S wasn't one that I deemed necessary.
I like The A/S/S if I have to go to Phoenix or Prescott, lots more stoplights there than where I live.
And a nightlight is not something I want sticking out of the 110v outlet with my 70 lb. bird dog moving around back there.
