Aftermarket Radio Install
emerworth01
Evan
El Paso TX
2020 Ford Ranger XL STX 4x4
Hello All,
I have a 2020 Ranger XL STX. It currently has a factory radio that does not contain a touch screen display or any other features such as navigation, apple carplay etc. I was looking into upgrading to an aftermarket radio. Crutchfield makes a very nice conversion kit which allows me to retain function of my backup camera and steering wheel controls. My only concern is my remote start which currently works through the ford pass app. Does anyone know if the remote start module is through the headunit or if it is independent. Wiring diagrams would be helpful if anyone has them. Thanks!
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
I think there is a seperate telecommunications module in the trucks, so I guess it's not tied to the head unit.
Saucy
Utah
2022 Ranger Tremor, 2019 Hyundai Kona
Software Slave
The head unit is isolated from your remote start system, no issue there. That head unit is just an audio interface with steering wheel control and factory backup camera inputs.
I really like metra products, here are installation instructions using the metra kit. Really good products and support. http://metraonline.com/files/products/INST99-5857B_web.pdf
Don't use a universal or programmable interface for steering wheel controls, there are a couple brands that will integrate ford factory input > aftermarket like https://axxessinterfaces.com/product/AXTC-FD2
Hope this helps
evand4798
Evan
Florida
2020 Ford Ranger XL/STX
I have the same exact spec ranger as you, 2020 STX with the 4 inch sync. What I recommend is doing a 4 to 8 inch sync upgrade from 4d tech. If you have the extra money to spend, its the best upgrade option out there. It retains OEM look, and retains all your trucks settings, hotspot, remote start/stop, etc. I got mine from 4d tech ill attach a link below. Install was very easy as the parts are all OEM, it was a simple plug and play for everything. They will even pay you for your old headunit!
Sync 4 to 8 Inch Upgrade : https://www.4dtech.com/ranger-20-23-4-to-8-touchscreen-conversion-w-sync-3/
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
They make a seriously quality product. Everything is oem except a wiring harness. Works amazing too.
