30K factory warranty- anything I should check/have checked?
WheelMon
Otto
Vallejo, CA
autio.com
@Autio Travel App by Kevin Costner
I am approaching 30k miles on my 2019 Ranger STX4x4. Is there anything I should have the dealer check before exceeding the factory warranty of 30k miles?
Recently, I've been experiencing a bit of hesitation / bogging down in 1-2-3 gear street driving. It's the only issue I've encountered so far. Any thoughts or suggestions would be welcome.
Thanks for any feedback.
The factory warranty is 3/36 so unless it's an extended warranty or a dealers warranty where you purchased it you're already over it on the years. But I would have them do the transmission TSB if you already haven't done that which "should" help your transmission issue. Also change the diff fluids and the transfer case. When I did mine on my '19 the diff fluids were nasty and that was at 22,000 miles.
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
Thanks Scorp Dave! Shall do those.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
I also will be having all the fluids changed after the Trans TSB is finished. 5 years old with 21,000 miles.
AzureRanger
2006 Jeep TJ
Hey guys.....do any codes have to be showing before the dealer will do the trans TSB? My '23 is "jerky" in the lower gears, but not sure if it is the same that so many are experiencing. I'm at 18 months and 11k miles. Thanks.
Stevedbvik1
2022 Ranger Tremor XLT
They will check for codes but not required to initiate the TSB.
Stevedbvik1
Also, what’s your build date?
AzureRanger
2006 Jeep TJ
Can't remember exactly.....it was Oct/Nov '22.....took delivery 12/22.
Edit: Received "built" email on 11/21/22.
Stevedbvik1
Anything after mid August 22 should have the update CDF drum. But they will confirm symptoms and first step will be reflash. Then if still acting up after you driving it for a bit they then move to the valve body.
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
Good idea! Thanks Chuck!
Robert. 'jerky' shifts in low gears is a better description of my symptoms.
Jason B
2021 XL STX SE 4x2
machinist
Bumper to Bumper is 3yr/36K
Drive train is 5yr/60K.
If you bought the truck on or before April 19, (your forum join date), you are out of warranty unless you bought an ESP.
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
Thank you Steve.
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
Thank you!
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
Thank you JB!
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
