- First Name
- Dave
- Joined
- Jul 25, 2019
- Threads
- 335
- Messages
- 26,319
- Reaction score
- 132,545
- Location
- Back Home In AZ!
- Vehicle(s)
- 2023 Ford Ranger Tremor
- Occupation
- Retired...Full Time Slacker
- Thread starter
- #1
I finally got around to using the new 303 Graphene last night and this stuff is really great. You can coat over any product including ceramic coating with this stuff. I wanted a fresh start so I washed, clayed and striped the old finish off with paint prep. The Graphene goes on very easy and you need to do a crosshatch pattern, you only need a few sprays on a microfiber pad or foam pad. I put way to much on the first panel and it was dripping and took forever to dry…less is more!
It takes about 10-15 minutes to haze over depending on temps and humidity so you can do about 1/3 of the truck then go back and buff out. It’s safe for all areas so I did all the glass, rubber around the windows and the headlights and taillights too. It gives you a super smooth mirror finish with great UV protection. I ended up doing a second coat just for added protection and you can clayed up to 3 coats. You can also use your favorite speed detailer or gloss enhancers after 1 week. The nice thing is there is no curing time like ceramic coating so once you’re done you can drive it right away. It can also be applied in direct sunlight which I wouldn’t recommend so it’s very user friendly. It’s supposed to last for 1 year and being a new product there’s no real world data yet but I’m confident it will as 303 makes great products and stands behind all of them.
Graphene Nano Spray: https://www.goldeagle.com/303-graphene-nano-spray-coating/
Graphene Detailer: https://www.goldeagle.com/product/303-graphene-detailer/
Bundle Pack: https://www.goldeagle.com/product/303-graphene-holiday-bundle/
