255 / 75 X 17 Tires = will they fit?
conductor
Rog
6z7DxXWKDVuLN9
2020 Ford Ranger
I have a 2020 FX4 Ranger, no lift, all stock. My question with all of the fitment issues, would this size clear my crash bars?
Or will I have further mods coming in the near future with this tire set up. I just want to go a little bigger and narrower with the stock wheels.
Any body try this combo on a stock Ranger?
UnregistredHypercam2
Jon
Denver, Colorado
1997 Toyota Land Cruiser VX Limited, 2013 Chevrolet Suburban LT
Cybersecurity
32's will not rub on crash bars. I didn't have rubbing issues until I made it to 35's.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Hope not - I just ordered 265/70/17s
maxbottomtime
NE OH
2021 Ranger XLT SCAB 4x4
Here
XLT
Three things to consider - diameter, width, and wheel offset. Those seem skinny enough to work with the larger diameter.
Stay with your OEM wheels and you should be fine. Move to lower offset wheels and it might be a different story.
YaBoiNewton
Florida
Automotive Engineer
I've got them on a 2" level so they definitely fit in my case, but there is a ton of space on all sides at full lock in either direction. They would definitely fit at the stock ride height. Gained a little over an inch of ground clearance when fully inflated. Highly recommended.
People are rubbing because they are getting significantly wider tires or widening the stance so much that the tires are pushed into the frame/crash bars when turning. Using the OEM wheels and keeping the width at or less than stock will avoid this problem.
Note this topic is incredibly nuanced and may be untrue for certain tire designs. But generally speaking, a 255/75r17 all terrain will fit a stock Ranger.
Todd Chapin
Todd
Alexandria
2019 crewcab lariat fx4
Chef
Your good on stock rims. Anything sized above that, well....
I have a 2.5 lift and true 32" tires but anything bigger.
Wytchdctr
Doug P.
2021 XLT
You were correct. Tires worked great until I traded it. Felt like they should have been the stock size IMO.
Highly recommend that size for on road use trucks for sure.
