JMagpie
- First Name
- John
- Joined
- Feb 27, 2021
- Threads
- 1
- Messages
- 10
- Reaction score
- 6
- Location
- Milwaukee, WI
- Vehicle(s)
- 2020 Ford Ranger Crew Cab 4WD
- Occupation
- Semi-retired
- Thread starter
- #16
Thanks again, but did that other forum happened to have any further details/definitions on these peramaters? I'm still having trouble decoding some of them to simple English!I found this on another forum.
Airflow
-MAF
-MAF_Khz
-MAF_Vlt
-BP- Barometric Pressure - inHG
-MAP - Manifold Absolute Pressure - ADC (Analog to DC counts at 10 bit conversation)
-BP - Baro Pressure - inHG
-Wastegate_DC - Percentage
Fuel
-Rear_02_Corr_B1
-Rear_02_Corr_B2
-Rear_02_Err_B1
-Rear_02_Err_B2
-AFR_Matured
-Clsd_Loop_Fuel
-DSD_Lamba - Desired Lambda
-FRP 1 - FRP Desired in PSI
-FRP 2
-Injection_Timing
-Act_Lambda_B1 - Actual Lambda Bank 1
-Act_Lambda_B2 - Actual Lambda Bank 2
-Lambda_B1 - Not Supported
-Lambda_B2 - Not Supported
-LTFT_B1 - Long Term Fuel Trim bank 1 in decimal format.
-LTFT_B2 - Long Term Fuel Trim bank 2 in decimal format
-Pulsewidth
-STFT_B1 - Short Term Fuel Trim bank 1 in decimal format
-STFT_B2 - Short Term Fuel Trim bank 2 in decimal format
-Open_Loop_Fuel
-FRP_Absolute - Actual FRP in PSI
-FRP_G
-Fuel_Level - Fuel level in percentage
-PM
Misc
-Engine_Torque
-Torque_Source
-MIL_Light_Is_On
-LOAD - Load in WHOLE numbers.. 0, 1, 2 etc..
-Run_Time - How long the calibrator has been on
RPM/SPEED
-DSD_RPM - Disired RPM
-Output_Shaft_Spd - OSS Speed
-RPM - Do I really need to tell you this one?
Spark
-KnkSen1_Cnts - Raw noise data from Knock sensor bank 1
-KnkSen2_Cnts - Raw noise data from knock sensor bank 2
-Lrnd_knk_Mod - Not sure?
-KnKAdder - Timing corrections based on knock sensor feedbacks
-Oct_Adjust - Reads 0 all the time?
-Spark 1
-Spark 2
-Spark 3
-Spark 4
Temp
-Cat_Temp_B1
-Cat_Temp_B2
-ACT
-ACT2 - Temps from Manifold in F
-CHT_Temp
-ECT 1
-ECT 2
-ACT2
ETC
-Act_Thrt_Ang
-Dsrd_Thrt_Ang
-Pedal_Pos
-Rel_ Pedal_Pos
-TPS
Trans
-Lockup_Status
-Output_Shaft_Spd
-Prk-Neu_Sense
-Spd-Ratio
-Turbine_Spd
-New-Dr_Status
-Conv_DC
-Slip_Across_Conv
-Conv_Current
-Ovrshoot_RPM
-Shift_Flare_RPM
-Shift_Lag_Time
-Shift_Slip_Time
-Shift_Sol_A_DC
-Shift_Sol_B_DC
-Shift_Sol_C_DC
-Shift_Sol_D_DC
-Shift_Sol_E_DC
-Solenoid_E_DC
-Cur_Trans_Ratio
-Gear_Commanded
-Shift_ID
-Shift_Type
-Tap_Down
-Tap_Up
VCT
-Ds_ExhCam_Pos
-Ds-ExhCam_B1
-Ds_IntCam_B1
-Ds_IntCam_Pos
-ExCam_Pos_B1
-Exhcam_Ang_B2
-ExhCam_Err_B1
-ExhCam_Err_B2
-IntCam_Ang_B2
-IntCam_DC_B1
-IntCam_DC_B2
-IntCam_Err_B1
-IntCam_Err_B2
-IntCam_Pos_B1
