MassRanger
- Thread starter
- #1
Is it possible to change from the 2.3 productivity screen to the 4.2 screen? I'm really tired of the black and blue screen
Gauge cluster / instrument cluster, not dash*You are talking about the screen in front of the steering wheel right? if so you need to change the whole dash, which has been done. you will need to find an XLT dash with equal or less miles than yours. You can increase the odometer mileage to match but not decrease. There are threads on replacing the dash on here
If the donor cluster has higher mileage you are stuck with that mileage. if the donor cluster has lower milage you can use Forscan to increase the mileage to match your current mileage. its been done.Gauge cluster / instrument cluster, not dash*
(don't mind me)
It can be done but you'll need to find a donor cluster with similar or higher mileage.
Not sure what happens if you swap in a lower mileage cluster...
Yup you're correct, I keep forgetting about forscan..If the donor cluster has higher mileage you are stuck with that mileage. if the donor cluster has lower milage you can use Forscan to increase the mileage to match your current mileage. its been done.
With the OP having a MY 2021 it may be fun finding one with lower mileage.
