19.99 bore scope
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Tried mine last night with the little screw on hook. Pulled those old Big Mac's right out. No 303 involved ?
seasprite
seasprite
Missouri
2022 Ranger XL STX
Changed my oil and transfer case oil yesterday and decided to get a couple pics with the camera.
I did try to look at my intake valves for cylinder 3 by removing the sensor next to the DPFE sensor and couldn't get it snake up to cylinder valves.
Did try to take look in the transfer case though the fill plug but there was some kinda plastic tube in the way and I already put the drain plug back on with the new crush washers.
Did take a look into cylinder 2 at the piston though. All I run for fuel is 91 alcohol free, and there is some carbon at edges. Might toss some cleaner in the gas tank and see if it cleans up. 35k on the truck.
Those pictures are really clear for a $20.00 scope. Nice score!
Played with the Bore Scope today.....
Took off a few of the rubber plugs I installed under the rocker panels over 2 years ago, and fed the scope up to check for any rust/moisture that might have accumulated, and found none. Also ran it up thru several of the holes in the frame rails and found them clean.
Very handy for checking....well worth the $20 bucks to check areas like those. :like:
Similar threads
